b20b burning oil rebuilt with b18a1 head obdo need help
Old Jul 16, 2014 | 02:43 PM
efsedanb20's Avatar
Default b20b burning oil rebuilt with b18a1 head obdo need help
Burning a lot of oil the pvc valve that runs from the intake to the pvc valve under the fuel rail isn't hooked to anything I know the b20b valve cover has the pvc valve on it . I have b18a1 valve cover and head would it be possible to drill a hole in valve cover like the b20 has and install the pvc valve ....
Old Jul 17, 2014 | 08:35 AM
RanCRX's Avatar
Default Re: b20b burning oil rebuilt with b18a1 head obdo need help
Probably a good idea to have that pcv installed and correctly routed. If you are burning oil out of your exhaust pipe, then you may wanna check other things. If you are getting smoke from the engine compartment, time to start checking where are the leaks, and doing some research on how to fix them if you don't know how to correct them
Old Jul 17, 2014 | 11:49 AM
efsedanb20's Avatar
I was going through it at lunch and found out I don't have the vent box on back of block now I gotta find one and see how much it'll cost .
EKredpanda
May 13, 2015 06:36 AM
patrick4588
Jan 14, 2008 06:08 AM
civbeater90
Oct 26, 2003 04:11 PM
drjondurst
11
Jun 7, 2003 11:15 AM
GruvyTune
Oct 22, 2001 01:29 PM
