RDX injector conversion obd2b
No need for conversion harness, soldering or crimping. Just get the Toyota clips (p# 90980-11875), dissemble OBD2-connectors and then re-pin your original connector pins.
Pull tab out.
Then push locks and pull wire and connector pin out.
Install connector pins to the Denso-clip.
OBD2 connector pins won't lock properly to the Denso-clip, but when you push white locktab back, they stay in there.
Done.
Not the answer your question, but I hope this helps.
Pull tab out.
Done.
Pull tab out.
Done.
Pull tab out.
Done.
From what I found, the injector clips should be on the following models:
Toyota Camry 2002-2011 (even hybrid)
Toyota Celica 2000-2005
Toyota Corolla 1999-2011
Toyota Echo 2000
Toyota Highlander 2001-2006
Is that right?
Toyota Echo 2000
Is that right?
