Help with 4d spoiler
HEy guys,I got a stock spoiler for my 3rd gen 4door teg and was wondering if you guys know where the bolts go?Becuase I see no logical spot where the bolts should go thru.Any help from 4door teg owners with spoilers would help alot to.Thanks alot
From what I saw, they traced out the footprint of the spoiler on a large piece of paper then taped it to trunklid as a guide before drilling.
The bolts went thru the square metal rods on the underside of the trunk lid.(Kinda hard to explain)
You can purchase a JDM 4dr ITR spoiler right here: http://www.jdmpartz.com/94in4doortyp.html
As far as the bolts go you should be able to see them on the underside of your trunk. If a 2dr spoiler was fitted on your 4dr the bolts should be hidden probably under the rubber plugs. Tiwst them out and see if there are bolts under there
