headgasket compression ratios
Well my all motor build has turned into wanting an extra 75-100hp so i started thinking about a low boost setup and now im weighing my options on lowering compression or doing a ton of research on making it safely tuned the only thing is here in hawaii all I got is 92 rated octane here in oahu. My goal is 300-325 on conservative tuning I always run the highest octane they have and that's what it is here. I'm not setting my goal on a specific lb of boost, my goal is to have that extra 75hp safely on my high compression build. I was also hoping since I want such a low gain I could get away with my current c/r ratio any thoughts?
Wiseco 88mm 11:5:1
Pro 1 cams and valvetrain
I kno there is diff. Layer gaskets but is it a pre determined thickness that will I guess "guarantee" a compression drop?
Wiseco 88mm 11:5:1
The thicker the head gasket, the lower your compression will drop. I've read however, that the thicker the gasket, the better chance it will leak.
Search is your friend, I know this info is readily available
poormans_typer69
Apr 21, 2008 05:37 PM
madman604
Jun 2, 2003 11:09 AM
