bogging down
have a 1997 civic lx. have replaced 02 sensor s plugs wires cap rotor. after it runs for about 10min it boggs down and starts sputtering and barely runs. runs pretty good for the first 10 min. little miss about 35to40.the exhaust pipe glows cherry red after the cat if you keep running it after it starts bogging down. any ideas of what to look at thanks.
yes on codes 23 codes mostly misfire banks 1234 o2 sensors af sensor. replaced all that. was going to take it back and get a readout. but something drained the battery in less than two hours.short somewhere maybe the ecm
well i jump started it took it to auto zone . .2 miles somewhere the check engine light went off the only code on it is 0705 transmission position sensor.ran it 4 more miles started boggging again. this time i noticed or i looked sooner but it was red farther down the pipe about 10" from the cat and right under the cat about 1" ring.
When it bogs you say it's only throwing the transmission code? That's hard to believe because it sounds like your car is about to blow up. Is this an automatic?
google "red hot cats" and u will get plenty of posts. my old car did that after the engine got "washed" in coolant. but yeah red hot cats means the fuel is not burning correctly in the cylinder and is BURNING IN THE CAT. kind of a big deal.
check engine light came on again po501 speed sensor.since it has the problem when it heats up i checked the coolant sensor i am getting 10 volts instead of 5 on the supply from the pcm. is the pcm faulty?
The ECT sensor is located below and just forward of the distributor.
