12v Ignition source for power windows?
Old Jul 12, 2014 | 10:31 AM
austinramsay's Avatar
Default 12v Ignition source for power windows?
Changed a bad ignition switch on my crx and the previous owner had the power wire for the windows tapped into the ignition harness. Is this an okay method? Or should I be rewiring it differently? If i'm going to do it the same way what color wire do i need to tap into on the harness? Should be the black/yellow wire correct?
Old Jul 12, 2014 | 11:01 AM
Tyson's Avatar
Default Re: 12v Ignition source for power windows?
Use the 3 accessory power ports in the fuse box. Three squares with male spades. One is constant, ignition, and headlights. Easy to figure out which.
0TT
Dec 31, 2007 11:49 AM
jadugartir
May 22, 2005 01:26 PM
Muckman
Audio / Security / Video
21
Jul 9, 2004 08:51 AM
mugenracer
Apr 3, 2004 05:50 PM
tzenisj
Mar 19, 2004 05:39 AM
