Removing front drive shafts
Old Jul 11, 2014 | 09:07 AM
Pellegrino_10's Avatar
Default Removing front drive shafts
I have a 2001 Honda Prelude SE and I'm trying to pull my front drive shafts out so I can remove the engine. I was wondering if it is possible to remove the axles without having to touch the lower control arm ball joints? Or is that impossible and I must remove the lower control arm ball joints?
Old Jul 11, 2014 | 08:55 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: Removing front drive shafts
Try the upper arm ball joints and tie rod ends.
Why do you not wanna undo the lower?
Old Jul 11, 2014 | 10:51 PM
holmesnmanny's Avatar
Actually the easiest way to pull the shafts while doing as little work is to actually pull the lower ball joint after removing the brake line bolts and you can just gently and quickly pop out the shafts from the tranny using a decent size pry bar and then just lift the knuckle out of the lower ball joint and turn/slide it away from the front of the car with the axle nut and axle still attached. I like to put the lower ball joint castle nut back on so that the threads don't get damaged during knuckle movement.
http://www.harborfreight.com/3-4-qua...tor-99849.html
http://www.harborfreight.com/tie-rod...ller-1752.html
Either of those tools will work to remove the lower ball joint, and any ball joint for that matter.
Old Jul 17, 2014 | 04:40 PM
yohan's Avatar
Princess Auto, picked up a tie rod tool that works great on our upper and lower ball joints ... it was $15. so much time saved.
Old Jul 17, 2014 | 05:48 PM
crazes's Avatar
Moderator
remove the lower ball joint and be done with it. Its actually 30x harder to remove it without taking the lower ball joint out
munoz86
Dec 4, 2008 03:59 AM
C00kiemunstr
Oct 1, 2008 02:55 PM
tree fingers
Feb 18, 2008 10:41 PM
2camsaam
Oct 2, 2003 07:30 AM
2camsaam
21
Oct 1, 2003 07:32 PM
