Turbo ek idles low, CEL comes on o2, no power, tried everything
Old Jul 10, 2014 | 10:18 PM
Treflipboy's Avatar
Default Turbo ek idles low, CEL comes on o2, no power, tried everything
Ok, got a question.... i got an turbo ek coupe, 98 to be exact. converted from obd2 to obd1, has a b20 block, b16 head, and b16 trans. Car has RC 550 injectors, aftermarket fuel rail, pump, adjustable FPR... SO today randomly i went to start it and it had a prolonged crank, once it started it was idling at about 400 rpm's for a second or two, thenm jumped up to 750 and CEL came out. Checked code and it was for o2 sensor, but i have no o2 sensor! Never had this issue before, ran good. Car is chipped and tuned, and when you drive it, if you ease your way into throttle, it'll drive fine! full power, spools, and everything.. but if you snap throttle the car jerks around and studders, almost like it's not getting enough fuel or spark is off or something. Firing order is correct, Fuel pressure at idle is perfect, all injectors are firing. I've also tried to reset ECU, and have tried using different ECU's. Any ideas are welcome, as long as they are well educated guesses! lol
Nothing was changed, drove somewhere, parked, got down and 15 minutes went back to my car and it started doing this. I'm stumped!
Old Jul 11, 2014 | 03:13 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Turbo ek idles low, CEL comes on o2, no power, tried everything
Well now you do. Either add one or remove it in the tune.
Treflipboy
Jul 13, 2014 11:51 AM
WhiteEkCivic
Nov 21, 2008 11:55 AM
teg_racer
Dec 11, 2007 09:46 PM
boostinh22
Nov 29, 2005 11:15 AM
DualCamEK
10
Dec 25, 2004 08:01 AM
