Honda Starting issues - with pic!
Old Jul 10, 2014 | 07:07 AM
Lockheed8000's Avatar
Default Honda Starting issues - with pic!
Hello!
I have a 92' Del Sol with a D16Z6. It's a real sweet runner, but it has allways had an issue reguarding hot-starts after a short run (or when it is warmed up). The problem occurs when the engine is warmed up after a short run. It won't start if i turn it off, and then try to restart it. It has to cool down first, and then it starts no problem.
I cheched the forums and found that many said it might be the igniter or coil.
I then took apart the dizzy to check and found this miscoloring-rainbow type of spots on the coil itself. I'm thinking that this means that it is the coil that is causing my hot-start problems?
Any thoughts on this before i order a new coil? Or am i completly wrong?
PS! it was kinda hard to capture the miscoloring on cam...
[IMG][/IMG]
link to pic: http://tinypic.com/r/dhaaea/8
motegicivic
Jun 7, 2012 12:49 PM
Michael.K.Conte
May 29, 2010 12:01 PM
Amadeus
Oct 27, 2002 07:38 PM
