2000 Acura Integra GSR
Old Jul 10, 2014 | 06:07 AM
skylixz's Avatar
Default 2000 Acura Integra GSR
Okay I have 2 problems. I'm a picky person so even the smallest of things that's wrong with my car I want fixed.
1) my cigarette lighter doesn't work. (No I don't smoke; use for a car charger) I check the fuses. Everything as far as that goes is good because I replaced all the bad ones. So any idea what my next step should be.
2) I know my fuel gauge works to tell me when I need gas but I would my fuel light to come on when I'm low. I've almost ran out of gas cause I wasn't paying attention and was on a highway. Of course we all see bright lights on the dash. I haven't checked the bulb but if it's not bad what could that be?
Old Jul 10, 2014 | 06:17 AM
Loverice's Avatar
Default Re: 2000 Acura Integra GSR
u might need to replace the liighter unit its self there dirt cheap. did u pull it out of the dash and see if any of the wires connected to it came undone?
Old Jul 10, 2014 | 06:37 AM
skylixz's Avatar
Yea I was reading that on a few forums but I work everyday so by the time I get off I think junkyards or wherever I can get them from will be closed.
& yes I did . I have pictures but I don't know how to add them
Old Jul 10, 2014 | 09:31 AM
skylixz's Avatar
S
Old Jul 10, 2014 | 09:32 AM
skylixz's Avatar
sorry about the double posts too. If I knew how to delete that I would.
Old Jul 10, 2014 | 02:25 PM
thewrai6th's Avatar
Are you new to the GSR? I'm guessing you didn't run out of gas, and your gas light was not on, because you were not that close to being out of gas. The gas light in a Intergra comes on at or below the E line. When I fill up at E, I can only put in 10-11 gal, giving me 2 more gallons reserve. For the first year I owned my car, I thought the gas light was broken.
For the lighter, you might need to ebay a new one/run new wires from the fuse block. It should be off a ACC switched circuit (turns off with radio).
Old Jul 10, 2014 | 07:52 PM
skylixz's Avatar
Yes I'm new to a GSR. Just got it June 27th..& I been sitting on E a few times. I thought when you were at about 1-2 gallons left it would come on, especially looking at it sitting on E..
& I'll try to get a new one. Do I have to get that whole assembly (with the coin tray) or can you just remove that cigarette lighter piece?
Old Jul 10, 2014 | 10:03 PM
shotoutacc0rd's Avatar
Did you pull off the that piece to make sure everything is plugged in? It should only have a few screws holding it in. You should also try cleaning the electrical connector with "electrical connector cleaner" before buying new parts.
Old Jul 11, 2014 | 04:04 AM
crazyhouse2011's Avatar
Forget what these guys are telling you about the cig lighter. Get your flathead screwdriver out and a flashlight. shine the light in the socket and look in there. there are two metal tabs that sit opposite to each other in the socket, way in the back. Sometimes over time these get pushed against the walls of the socket. Use the flathead to pry them off the walls of the socket. Use the oem cig lighter to see if it will hold if you push it in. If not, pry the tabs out a little more. do it until the cig lighter stays in on its own and then pops out when its heated.
Old Jul 11, 2014 | 09:27 AM
thewrai6th's Avatar
Yeah, don't listen to us. We r just stpuid yo.
I didn't think this actually needed a full explanation. Yes, check the tabs in case you bent both of them off to the side. If that doesn't help you can get a multimeter and test the ground and the positive wire. It's basic electrical troubleshooting, 1-12v, 1-ground, and it's not an expensive part or hard to replace.
As far as the 1-2 gallons, I have 2 gallons left when the marker is right below E. You still have about 50 miles left when the light finally comes on.
Old Jul 16, 2014 | 11:30 AM
skylixz's Avatar
Okay. I haven't got below E or on it. I'm too scared to let it get that far and being sitting on the side of the road all day.
I fixed the cig lighter though. The wires weren't connected porbably. Whoever had it prior, tampered with it & messed up I guess trying to install the radio
Old Jul 16, 2014 | 11:31 AM
skylixz's Avatar
Now can anyone tell me why when
Old Jul 16, 2014 | 11:32 AM
skylixz's Avatar
Now can anyone tell me why when it rains, my windows fog up. It's summer time and I can only keep it clear if I have the heat on. I'm nt trying to be a human torch.
Old Jul 16, 2014 | 12:00 PM
hungrygreen_gsr's Avatar
It's condensation. Either crack a window open or turn the ac on. Does the ac not work?
Old Jul 16, 2014 | 02:56 PM
skylixz's Avatar
I don't see any cracks. That rubber molding piece that goes along the outside of the windshield, the piece is missing.
& no I don't have a/c in my car..
skylixz's Avatar
Would a/c help?
Old Jul 16, 2014 | 03:11 PM
Would a/c help?
oh man, i know those feels. no ac, rain on a hot steamy summer day, and your stuck toasting in a car with the heat on. **** that. I usually turn the defrost on, then pop up the sunroof so the hot air goes along the roofline and gets sucked out the sunroof. Most of the time your moving fast enough to where water won't come through the crack. Then turn on the rear defroster.
Old Jul 16, 2014 | 03:35 PM
skylixz's Avatar
Idk why I didn't think to crack it last night smh..but my rear defroster don't work. Trunk not even wired up. I just got the car. Just hate when people don't take care of their cars.
Old Jul 16, 2014 | 08:48 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
AC is what you want for defogging. It dries the air as well as cools it.
Old Jul 17, 2014 | 05:13 AM
skylixz's Avatar
I think on my older cars, my a/c didn't do much from defogging them. One I know worked for sure cause I recharged the unit
And my prelude was working properly
Old Jul 17, 2014 | 09:23 AM
B serious's Avatar
It's funny. On my older car, my battery never did much for starting the car. One I did know worked after I recharged it.
Weird.
myDC4rox
Dec 6, 2021 09:12 AM
skylixz
Jul 18, 2014 04:27 PM
tylerharter
Jun 10, 2014 10:34 AM
stupidceleb
15
Jan 12, 2011 09:26 AM
WalkerGSR1
Nov 24, 2007 07:44 PM
