h22 timing mark location issue.
Old Jul 9, 2014 | 09:53 PM
Manifest113's Avatar
Default h22 timing mark location issue.
hey guys i have a h22 with a h23 trans. I am trying to get the timing set on the motor all the top end stuff is lined up but i have a clutchmasters flywheel and me and 2 other ppl have looked and we cant find the tdc mark on the flywheel. my tuner says i need to get a harmonic balancer with timing marks on it or that we cant set timing correctly so no tuning. i am at a loss here and not sure what to do. and ive done the cyclinder 1 tdc allready so i know thats right but the car runs like serious crap.
Old Jul 10, 2014 | 12:31 AM
holmesnmanny's Avatar
Default Re: h22 timing mark location issue.
Looks like you got an obd2 flywheel. If it hasn't been that long, I would ask them to swap it out.
Your other option is to get an obd2 crank pulley and timing cover and swap it in.
Old Jul 10, 2014 | 03:03 AM
You could also have a tuner put in his ecu and with him monitoring the timing you can set the timing to 15 after jumping the service connector.
Old Jul 10, 2014 | 03:58 AM
I was unaware that obd1 and obd2 crank pulleys were different. I thought it was only some of the h23 crank pulleys that had a different pulley. So obd2s have timing marks on the crank pulley? Theres no way to swap the flywheel without buying a new one
anomale
Nov 30, 2008 01:34 PM
dahoopdahup
Nov 21, 2005 05:06 PM
blusmke
Jun 14, 2005 08:08 PM
92 in the works
Feb 23, 2004 07:30 AM
bgod
Jul 23, 2001 06:37 AM
