92 Civic starts briefly and then dies
How's it going I'm new to this forum, but I'm have a problem with my 92 civic it will start for a brief second then it will die and it pretty much does that every time I turn the key. I used starter fluid and the car started running for 2-3 seconds but then turned off again. Any help is very much appreciated thanks in advance.
There is a laundry list of questions that will be asked in order to find your problem. If you search your symptoms you'll find numerous threads just like the one you started.
After reading through those and findings some answers, come back with questions you still have.
eH.
eH.
Is your fuel pump priming? Check to see if your pump primes for 2 seconds and then cuts off if not check your main relay, search the faqs for testing and repair.
e_civic_92
Aug 23, 2011 09:56 AM
