H23A Vtec Straight Swap?
Old Jul 8, 2014 | 11:07 AM
4g4dcruisin's Avatar
Default H23A Vtec Straight Swap?
Minus the mounts, does the H23A vtec fit into the integra? I've trying to figure out why the H22 is so much more expensive than the H23A when the HP is the same.
http://www.sunrisejapanese.com/honda...ccord-351.html
http://www.sunrisejapanese.com/catal...47/category/4/
http://www.sunrisejapanese.com/catal...14/category/4/
Old Jul 9, 2014 | 03:39 AM
LSracing94's Avatar
Default Re: H23A Vtec Straight Swap?
h22 is easier to get parts for, more well known/well documented
there are small differences..I think the h23 oil pan is deeper, which would suck for swapping into a teg, and the pistons and rods are different than h22 from what I have read.
Power wise they are similar, but you could run into trouble trying to get some replacement parts I suppose
Old Jul 9, 2014 | 04:32 AM
Alright, just wasn't sure, I mean for roughly 1/2 the cost, I'd probably just go with the H23A vtec.
Old Jul 9, 2014 | 07:01 AM
Tight-R's Avatar
The H23 is a great motor to swap. It's a beast for the $$. The differences are subtle, which is why people go with these once their H22 bites the dust. I/H/E/Tune and these will make pretty good power. The advice above you doesn't make any sense.
Old Jul 9, 2014 | 07:04 AM
Tight-R's Avatar
Also remember it's not just like swapping in a b-motor, it's a little more involved. I would also suggest getting an H2B kit so you can keep your b-series transmission. An H23 with an a b16 trans or ITR trans would be a lot of fun in an Integra.
Old Jul 9, 2014 | 07:05 AM
I'm familiar with D and B engines, so excuse my ignorance to the H engine...but can't you swap out the H23 oil pan for the H22 oil pan? Is the oil pump larger on the H23 or is it just a larger block?
Either way, I'm not slamming, and I'll put a skid plate if need be. The H23A vtec blue top seems WAY worth the price. I'll also be doing the H2B swap.
I saw your second post after posting this one...but yea I don't have anything except for a shell, so my options are wide open. Probably going with an LS trans, don't need those shorter ratios.
Old Jul 9, 2014 | 07:22 AM
Tight-R's Avatar
Yuck, LS trans? At least get a GSR trans. B16 would be the cheapest with the best gearing.
There's things you need to do to the H23 to work with a USDM car, like swap the oil pump or something like that. Just look up H23 swaps (for preludes) and there's a whole writeup.
Here's a build, I didn't go through it. Should help a lot with any of your questions. Google is the ****.
https://honda-tech.com/forums/hybrid-engine-swaps-18/h2b-integra-h23a-vtec-3149087/
Old Jul 9, 2014 | 07:42 AM
https://honda-tech.com/forums/showthread.php?t=3149087
While I appreciate the input, I'm not a fan, nor do I want the attention of getting through 1-4th gear super fast hitting vtec with every shift. I prefer the longer gear ratio of the 4-5th. I might be talking out of my *** but I think the LS trans has the longest gear ratios.
I'm not building this for race, it will be street driven from time to time, but not a daily.
I'll check out that build, I'm very familiar with swaps, just not with the H or with the DC chassis.
EDIT: I've seen that post, dude got a little crazy with the grinder, I'll be going for an H2B kit.
Old Jul 10, 2014 | 03:35 AM
LSracing94's Avatar
my advice doesn't make sense? the oil pan/oil pump/bottom end its much different than h22 and most ppl seem to be very unfamiliar with them, making the h22 an easier swap.
If price is the determining factor then the h23 is prob the way to go.
Reason I bought up the oil pan is bc these h22 swaps already sit low, and im sure his car is lowered also..so with a deeper oil pan it will be closer to the pavement, more chance of hitting/ scraping it.
Old Jul 10, 2014 | 04:22 AM
I'll be going with the H23 more than likely.
Old Jul 10, 2014 | 12:38 PM
Tight-R's Avatar
I'll just leave this here. Don't give advice if you aren't sure of the answer.
https://honda-tech.com/forums/showth...1961&styleid=2
Old Jul 10, 2014 | 12:42 PM
well the H23A Vtec is from a Euro accord.
Nevermind!
http://en.wikipedia.org/wiki/Honda_H_Engine
H23A DOHC VTEC
In 1998, Honda of Japan produced a rare DOHC VTEC version of the H23A engine for use in Japan only. It has been factory modified with an internal oil passage in the H23A block to operate the VTEC solenoid in the H22A head. Having the same horsepower rating as the H22A engine but it has a lower redline because it has a longer stroke than H22A. H23A DOHC VTEC has 87mm x 95mm (bore and stroke)and the H22A DOHC VTEC has 87mm x 90.7mm (bore and stroke). The H23A DOHC VTEC Engine is largest displacement in the H Series engines with a compression ratio of 10.6:1.
Found in the Japanese 1998-2002 Accord Wagon SiR (CH9). It produces 200 PS (147 kW; 197 hp) @ 6,800 rpm & 163 lb·ft (221 N·m) @ 5,300 rpm and comes with a "blue top".
Found in the Japanese 1998-2002 Accord Wagon AWD (CL2). It produces 190 PS (140 kW; 187 hp) @ 6,800 rpm & 163 lb·ft (221 N·m) @ 5,300 rpm and comes with a "blue top".
Old Jul 10, 2014 | 12:46 PM
This is the motor...comes out to about $850 including shipping from NJ to MO.
http://www.jdmenginedepot.com/jdm_en...ngine_JDM_H23A
Old Jul 11, 2014 | 03:37 AM
LSracing94's Avatar
And also read this:
https://honda-tech.com/forums/honda-prelude-4/jdm-h23a-vtec-blue-top-mystery-motor-true-facts-questions-2341343/
Right from the sticky on HT
Rod Length
H22A4 = 5.633
H22A = 5.633
H23A = 5.572
H23A1 = 5.572
There is a lot of info floating around, how is anyone supposed to know what is true anymore with out actually doing it first hand?
Old Jul 11, 2014 | 04:58 AM
Welp, putting in a B20 or straight LS motor. Not going to screw around with H2B or anything fancy...I'm going for a good running, reliable and excellent looking build.
Rad Racing
Jun 12, 2012 11:04 AM
n0limitzracer916
Nov 22, 2006 03:11 PM
superturboprelude
Dec 29, 2005 12:57 PM
honda1992si
Jun 2, 2005 11:28 AM
Daysleeper
Oct 13, 2003 09:52 PM
