Gsr fuel pressure issue
Old Jul 7, 2014 | 09:44 AM
nicknack25's Avatar
Default Gsr fuel pressure issue
So my fuel pressure is pretty high up there from a cold start. Not sure if this is normal. With the fpr hose connected, psi is at 69 and with the hose disconnected and pinched off, it is at 79. The manual calls for 48-55 psi with no hose and 39-46 with connected hose. When motor is at normal temps, psi is about 57 with no hose and 48 with hose. Not sure if the pressure gauge is faulty because when i shut off the motor, the gauge doesn't return to 0 (not sure if its supposed to).
My question is is fuel pressure supposed to be that high at a cold start? Cause it sorta goes back to normal when the engine is warm.
I'm using a oem gsr fpr, AEM fuel rail and B&M fuel pressure gauge. (I only have the aem rail because it had the fuel pressure gauge on it)
Motor is stock with basic bolt ons swapped into a crx.
Old Jul 9, 2014 | 04:52 PM
IN VTEC's Avatar
Default Re: Gsr fuel pressure issue
Fuel pump?
Old Jul 9, 2014 | 10:24 PM
bigislandc2's Avatar
no thats to high. try swapping out a regulator if you have one..
although i have seen the b&m gauge go bad on several occasions
EG-SIXV-TEC
Jun 23, 2012 02:58 PM
boostedteg15
Jul 31, 2006 11:40 PM
Mr.EM1
Jan 6, 2005 11:17 AM
RTE117
Apr 8, 2004 05:18 PM
CHRIS 1.8
Mar 26, 2002 07:07 AM
