94 Honda Ex Misfiring.
Old Jul 7, 2014 | 05:44 AM
Dawit DT's Avatar
Default 94 Honda Ex Misfiring.
Old Jul 7, 2014 | 07:01 AM
Fitz Williams's Avatar
10 Year Member
Default Re: 94 Honda Ex Misfiring.
Have you pulled the Check Engine Light codes to see what the problem is?
Old Jul 7, 2014 | 03:04 PM
tim73's Avatar
When mine started doing this, it turned out to be the Ignition Control Module. You can remove it and have it tested, make sure you test it several times though, make sure it gets nice and warm.
Old Jul 7, 2014 | 08:01 PM
94 accord typeR's Avatar
blue 2 prong connector on passenger side under glovebox. use a paper clip and turn key to ON position then after a few sec the CHECK ENGINE light will blink. it will repeat codes until u remove key. u can find vids of this on youtube also
Old Jul 8, 2014 | 04:11 AM
MAD_MIKE's Avatar
MM Gruppe B
EGR valve doesn't get too sooted up, it is the EGR maniold(bolted to the intake) that gets clogged. Pull the codes. If the misfiring is during part throttle cruise, then most likely the EGR manifold is what needs to be cleaned.
jorgep82
Nov 18, 2013 12:15 AM
Npbriggsjr
Aug 13, 2010 12:48 PM
lowered94accord
Mar 16, 2007 08:27 AM
dgvandal
Jan 6, 2007 02:05 PM
Speed_69
Apr 14, 2006 04:48 PM
