Bad throw out bearing?
Old Oct 30, 2002 | 10:14 PM
Cereal_Killer's Avatar
Default Bad throw out bearing?
well here is the deal. i have recently heard a light noise when i start my car sort of like a squealing and seems to get a bit louder when i press the clutch in. well i tightened up on the clutch cable liek half a turn and it seemed to go away.
well my wife was driving home today and it was grinding (syncro's are fine, goes into gear w/o any problems so i don't think it's that). it made the noise everytime she pressed the clutch in. grinding whenever it was pressed.
could it be the t/o bearing or could it be somethign else?
[Modified by 91EFZC, 11:15 PM 10/30/2002]
Old Oct 30, 2002 | 10:16 PM
Trinity's Avatar
Default Re: Bad throw out bearing? (91EFZC)
that is what i would think it to be. someone correct me if i'm wrong
Old Oct 31, 2002 | 05:18 AM
keithv's Avatar
Default Re: Bad throw out bearing? (Trinity)
yep, sounds like the throwout bearing if it happens when you press in the clutch.
trinity's car makes that awful noise everytime you push in the clutch. hopefully we'll get that fixed this winter.
Old Oct 31, 2002 | 07:04 AM
Trinity's Avatar
Default Re: Bad throw out bearing? (breaka_1_9)
i can't bitch the tranny was 50 bucks, with no grinds
Old Oct 31, 2002 | 07:50 AM
Soled Out's Avatar
stop bitchin would ya
Old Oct 31, 2002 | 07:57 AM
keithv's Avatar
yeah i know....now you'll spend another $50 just to get a new bearing.
Old Oct 31, 2002 | 09:40 AM
PaImportTuner's Avatar
ok mine makes it when my clutch is engaging(WHEN DOWNSHIFTING). and accelerating in 1st gear and it stops in the middle of 2nd then in 3rd,4th 5th... no sound . when I'm idling it makes this swooping sliding sound.. then when i press clutch in it stops til i let go and it makes a ::tuck:: sound. Tranny goes into all gears great but it just feels a bit rough when shifting especially powershifting it feels like the tranny is going to fall apart or something.
what might be my problem.. the clutch doesnt slip and it grabs really hard in all gears?...
oh and another Q does a 90 CRX Si have a speed governor or rev limiter, because my fricken tranny revs to 7500 and i dont go passed that to see how high i can go. and in 5th gears i turn 6k. when 7k rpm and shifting to 3rd real fast my gear crunches in??
Old Oct 31, 2002 | 09:54 AM
keithv's Avatar
Default Re: Bad throw out bearing? (PaImportTuner)
ok your post was hard to understand, but...
if the noise goes away when you engage the clutch, the mainshaft bearing is bad in your tranny.
Old Oct 31, 2002 | 10:01 AM
Trinity's Avatar
damn you i wanted to get that one too. yeah its the mainshaft bearing and FIX IT RIGHT AWAY. if not it turns into a horrbile disaster. it isn't like a throwout bearing that you can kinda wait on. trust me i destroyed a tranny
Old Oct 31, 2002 | 12:08 PM
86_CRX_FOR_LIFE's Avatar
i have kinda the same **** going on over here?? but the grinding type nose goes away when i push the cluch in?? soon as i let it out it starts back up. no problems shiftin or anything. just nose???? anybody know?? me my self was hopein it is just the trow out bearing???
Old Oct 31, 2002 | 12:12 PM
Default Re: Bad throw out bearing? (86_CRX_FOR_LIFE)
o and it dose not do it well i am crusin in a gear just sitting in N with the cluch out nasty nose. push it in it's all good
Old Oct 31, 2002 | 12:14 PM
keithv's Avatar
i said 3 posts above:
and then you aksed:
did you not read my post?!??!?!
Old Oct 31, 2002 | 12:50 PM
yea u said main shaft well he's **** doing it in the gears. i was just hoping i was lucky. and it was not that
Old Oct 31, 2002 | 12:58 PM
scn095's Avatar
Easy one to remember:
->If the noise is only when the clutch pedal is depressed, give it a Prozac and replace the throwout bearing.
->If the noise is when your foot is off the pedal replace the mainshaft bearing.
[Modified by scn095, 8:07 AM 11/1/2002]
Old Oct 31, 2002 | 12:59 PM
Jonathan_ED3's Avatar
I wonder what the source of your problem could be
Old Oct 31, 2002 | 01:15 PM
Trinity's Avatar
no he said when you engage the clutch in the noise goes away and that is the mainshaft bearing. well guess what your noise goes away when that happens too
Old Oct 31, 2002 | 03:54 PM
Default Re: Bad throw out bearing? (hot_EG)
hey idiot if your refering to me not knowing how to shift or that the clutch is real good thats not what i meant... I mean in all gears either racing or daily driving the cltuch is harsh in both conditions like i have a 6 puck clutch. get me now? so its probably my throw out and my main shaft bearings hahaha can anyone say new tranny!
Old Nov 1, 2002 | 03:09 AM
keithv's Avatar
if you wanna get rid of that busted tranny, let me know as i'll grab it (if its no too much $$$). and i'll pick it up if you'll meet me in the NY/NJ area...
Old Nov 1, 2002 | 07:23 AM
scn095's Avatar
If the noise occurs only when the clutch pedal is depressed, give it a Prozac and replace the throwout bearing.
If the noise occurs only when the clutch pedal is up replace the mainshaft bearing.
[Modified by scn095, 8:24 AM 11/1/2002]
Old Nov 1, 2002 | 01:22 PM
anyone know which t/o bearing i will need? would it be 88-89 integra, or 88-91 civc/crx? i have a zc motor and tranny combo including the intermediate shaft.
Old Nov 2, 2002 | 10:00 AM
keithv's Avatar
i would get the 89-91 civic/crx throwout bearing. i have used the ZC and Si tranny cases and they were the same.
black96
29
Jan 3, 2016 08:34 PM
DeeJaaY209
14
Sep 15, 2013 10:40 PM
04civicex84
Honda Civic (2001 - 2005)
Nov 13, 2008 02:44 PM
abscher1
Jun 26, 2007 05:57 PM
s2kkk
Honda S2000
14
Jan 28, 2006 07:54 PM
