1998 Civic Power Steering Broken
Old Jul 4, 2014 | 12:40 PM
roxics's Avatar
Default 1998 Civic Power Steering Broken
Took my car in about a month ago to get a new subframe put in. A week later I got the car back and all seemed fine. Although they said they had some alignment issues so my steering wheel is not perfectly straight (just an inch or two off center). Other than that the car drove fine. Then about a week and a half ago I noticed my car felt a little funny. Vibrations in my clutch and brake pedals and a little harder to turn the wheel. Five days ago I no longer had power steering at all.
What could be the cause of this? Something they did while putting in the new subframe I assume? If so what is the most likely area/part that could be causing this?
Old Jul 4, 2014 | 12:54 PM
grumblemarc's Avatar
The Grumpiest
Default Re: 1998 Civic Power Steering Broken
Have you gotten under the hood or under the car to look at anything?
Old Jul 4, 2014 | 01:25 PM
roxics's Avatar
Yeah I have. But then I don't really know what I'm looking for either.
Old Jul 4, 2014 | 01:26 PM
The Grumpiest
Take it back to the shop.
Old Jul 4, 2014 | 02:46 PM
Former User's Avatar
Check the PS fluid level in the reservoir. Is it full?
Check the PS pump belt. Is it tight? With the engine idling, does the pump pulley turn?
Are any of the PS hoses or lines pinched or crimped?
By the way, it's not difficult to remove to steering wheel and get it positioned straight ahead by moving it a tooth or two on the steering column shaft.
Old Jul 5, 2014 | 02:10 PM
Nos651's Avatar
If a shop did the work just take it back.
Linh.
18
Apr 15, 2011 02:36 AM
sneekz206
Feb 1, 2011 03:41 PM
JBirch_97Prelude
Dec 6, 2007 07:53 PM
Dongoesby
Dec 24, 2005 11:07 PM
Milano_EH3
May 31, 2005 06:14 PM
