Rear speaker mounting on HB without pods??
Old Jul 1, 2014 | 09:09 PM
89SiZero's Avatar
Default Rear speaker mounting on HB without pods??
what are some ideas on how you guys have mounted your rear speakers that have hatchies? and does anyone know where the rear speaker wires are at? probably a stupid question, but, i cant seem to find em...any help appreciated.
Old Jul 2, 2014 | 03:04 AM
Freemananana's Avatar
Default Re: Rear speaker mounting on HB without pods??
Go to the junkyard and find these:
Or buy aftermarket
Or something like this
The wires are probably just clips if they are run back that way.
Old Jul 2, 2014 | 08:27 AM
David_S's Avatar
I've been searching for the first one. (Anyone have one PM me).
The 2nd on is carbon fiber and really expensive. Hover it will probably allow you to fit 6.5 instead of just 6.2 in the hole.
The last ones seem to be out of a CRX or 92-95 hatch. Can anyone confirm this for me? And will this bolt into a 89-91 hatch?
Old Jul 2, 2014 | 08:36 AM
If that's an EG (24TEN confirmed it is) it's probably a different shape. I'm sure you could make it work though. I mean, you can always cut a hole in the rear plastic and bolt the speaker covers over it.
Old Jul 2, 2014 | 08:58 AM
24TEN's Avatar
PHANTOM MENACE
It's from a 92-95 (EG) civic hatch. Just confirming.
Old Jul 2, 2014 | 10:31 AM
cjwang2's Avatar
I've got an extra set of speaker pods. If you are interested, pm me. Also, if you want to mount the speakers without the pods, you can always get the speaker brackets from the front doors, cut out the bottom, and then mount them on the cargo shelves. Should fit fine. I did that on mine before I got my speaker pods. Those brackets are very easy to find.
Old Jul 2, 2014 | 10:33 AM
cjwang2's Avatar
pic:
Old Jul 2, 2014 | 10:42 AM
David_S's Avatar
Originally Posted by cjwang2
pic:
Thanks for the idea.
I got a set of the ones for the fronts. I had to make some from the front out of plywood as the 6.5" speakers that I found wouldn't fit them.
LOL Currently I just have to 6X9s sitting in the truck wired up no box or anything.
Old Jul 2, 2014 | 01:34 PM
Jaime 91SiB18's Avatar
Icon4 Re: Rear speaker mounting on HB without pods??
Yes, we can cut them to barley fit the 6.5"
Here is Chris' [iheartteal] hatchback with 6.5" Momo speakers
Old Jul 2, 2014 | 09:58 PM
89SiZero's Avatar
What are thewirecolorsfor the rear speakers? That, putting the front speaker holders in the rear is a brilliant idea. Ima try it. Thanks so much guys: )
Old Jul 3, 2014 | 08:26 AM
cjwang2's Avatar
The wires should be blue and red. Open up the rear panels by the rear struts, I think, and there should be speaker wires already there, you may have to fish them out. drill a hole in the bottom of your Cargo shelves and run the wires through there. All hatchback trims have these wires there, even the base models.
Old Jul 3, 2014 | 03:36 PM
smilindave's Avatar
for my wifes car, I got a cheap pair of 6x9's put them in boxes with 5' of wire so she can metal out wherever she goes. (btw she is 54) added a 40x4 amp and now it is really good at higher volume levels. front speakers act as mid/hi and the rears fill with low end. I was shocked at the sound from the rear. Not bad for yard sale finds.
Regards
Dave
egvtec
Audio / Security / Video
Jan 16, 2009 05:56 PM
calinomad
Oct 5, 2006 12:15 PM
calinomad
Sep 22, 2006 09:40 AM
al3e
Jul 20, 2003 07:48 AM
hatchboy93
Apr 24, 2003 10:29 AM
