91 crx with stock ecu and d16y8 motor
Old Jul 1, 2014 | 05:50 PM
snowuh's Avatar
Default 91 crx with stock ecu and d16y8 motor
So I bought a really cheap crx not too long ago. It is a d16y8 but the car is using the original ecu. It runs fine (doesn't get that great of gas mileage...maybe 24-27 or so) but the vtec isn't even hooked up at all.
My question here is:
-Can I get the correct wiring and essentially "plug-in" the vtec solenoid?
-If not, what will it take to get it running correctly.
The wiring really is kind of a mess...the swap was obviously not done by a professional...It runs pretty well nonetheless.
Thanks in advance for any helpful answers.
Old Jul 2, 2014 | 05:29 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: 91 crx with stock ecu and d16y8 motor
The closest ecu to run that without issues is a P28 but that will require converting your ecu to obd1. You'll also need an OBD1 distributor. You'll then need to wire up VTEC.
turbod16y8
13
Apr 7, 2011 02:40 PM
wastedyouth2542
Dec 6, 2010 07:47 AM
vahonda97
12
Oct 13, 2006 06:53 PM
murmur9
11
Jul 28, 2004 11:14 AM
