2 check engine lights at specific condition - P0420 / P1456
Old Jul 1, 2014 | 07:05 AM
type Gendy's Avatar
Default 2 check engine lights at specific condition - P0420 / P1456
I recently picked up a great 98 EX with 169k miles. I knew it needed axles and brakes, but to my dismay the check engine light came on the next day, after being assured there were no other issues with the car. I pulled the codes and discovered a P0420 which i knew was (catalyst system efficiency below threshold), and could be very tricky to diagnose as i experienced on another vehicle. The second code was a P1456, which i was unfamiliar with. After a quick search i see its EVAP Emission Control System Leak Detected ( fuel tank) pressure leak; and also reportedly very tricky to diagnose.
Anyway i reset the codes, and they were gone for a couple weeks, and then came back. I reset again, and they returned another 2 weeks later, and i quickly realized, they both appeared when my fuel gauge would be one "notch" below half a tank. I always put a full tank in and run it low, and repeat. This has happened 6 times so far...
While I can do the research on the two codes as they relate to accords, and possible causes, i was wondering if anybody sees any significance to the codes appearing at a certain point in my fuel level. Anybody experience this?? Any advice on the codes is welcome, but i just found it very intriguing how it related to the gas gauge!
Old Jul 1, 2014 | 08:06 AM
tim73's Avatar
Default Re: 2 check engine lights at specific condition - P0420 / P1456
The catalyst, many times means teh cat needs repalced. You can run a check on your downstream O2 sensor. The evap leak, these are tricky, many times, it is a cracked or broken rubber hose. Smoke test is normally the best way to find it, if you have access to one.
Old Jul 1, 2014 | 02:17 PM
MAD_MIKE's Avatar
MM Gruppe B
Test your fuel pressure when the tank is full, and when the code comes back.
If there is a pressure issue, this would set off the 1456 code and can affect the running of the engine to cause it drop below catalyst threshold efficiency.
tylerzero
Honda CR-V & Element
Oct 27, 2022 07:21 PM
SGarrett
Jun 1, 2017 11:59 PM
slow-ef
Nov 4, 2008 07:51 AM
drkns
Jul 21, 2006 09:11 PM
2005 TSX
Mar 17, 2005 10:58 AM
