Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Three codes for the Emission system - needs help
Old Jun 30, 2014 | 03:05 PM
E019110's Avatar
Default Three codes for the Emission system - needs help
Hi folks. I posted an introduction so I'll cut to the chase. 2002 civic Ex tripping 3 codes. P1259, P0401, and P1457. I just got this car and I do have the maintenance records. Last time the PO took it to the shop the dealer replaced the VTEC solenoid and cleaned the EGR ports. Light came back on and I do not know how long after the service. So can you offer some advice on were I should start. I'm a field service engineer on gas turbines so I do know my way around a tool box
Old Jul 4, 2014 | 09:30 AM
E019110's Avatar
Default Re: Three codes for the Emission system - needs help
Cleared the codes and the P0401 came back first so EGR valves it is. Searched for any vacume leaks but didn't come up with any. Anything I should look at first before I change the valve?
Old Jul 7, 2014 | 03:52 AM
E019110's Avatar
EGR valve is new so I removed the intake manifold and the passages were solid with carbon. Car had been at the dealer not long ago and they billed the PO for cleaning the passages. The must have just sprayed some carb cleaner down the EGR hole and called it good. No way that light was going to stay off. So that issue is solved for now. I'm getting a surge during light acceleration, which was there before I R&Red the intake. I'm thinking air leak in the induction system so I'll look into that. Anyone have any other ideas?
Old Jul 9, 2014 | 05:00 AM
E019110's Avatar
Found a loose connection on the throttle body to air cleaned box joint. Secured that. Car has tripped the Aft O2 overvoltage code. The connection to the sensor was loose and dirty so I corrected that and cleared the code. I'll drive it for a while and see if it comes back. If so we will R&R the sensor.
Old Jul 9, 2014 | 05:21 PM
E019110's Avatar
Ok some progress. The 02 code has not come back. The car hesitates during acceleration. It's worse during a accel in 3rd. I changed the plugs which were pretty worn and it dose have more power but the hesitation is still there. Looking for any suggestions.
Krael
Aug 30, 2018 09:47 PM
seanyboy
Sep 3, 2007 06:15 AM
BB6racer
Dec 20, 2005 03:33 PM
chieny
Dec 2, 2005 11:29 AM
