What these do these mean for trans?
Old Jun 29, 2014 | 07:40 PM
greyEG's Avatar
Default What these do these mean for trans?
Got the trans out, but not after rusted bolts and broken pry bars lol.
My trans is out. So i was spinning the input shaft and i hear a clicking noise, is that the ISB or is this normal?
And i see some red dust? Is that from the clutch..? That normal or bad also?
Old Jun 29, 2014 | 07:44 PM
B_Swapped93's Avatar
Default Re: What these do these mean for trans?
the dust is fine I had lost when i pulled mine for the first time, as for the clicking can't recall if mine did that when I spun it.
Old Jun 30, 2014 | 04:16 AM
greyEG's Avatar
Thanks
Any more?
bump1
Old Jun 30, 2014 | 03:12 PM
crazyhouse2011's Avatar
Originally Posted by greyEG
Thanks
Any more?
bump1
Bro. IF you have your transmission out you might as well spend the money for the ISB while your in there. Like 20-60 bucks depending on your car. Just do it, piece of mind.
Old Jun 30, 2014 | 04:21 PM
TheRealTegger's Avatar
Is this when the transmission is in neutral? In neutral there ought not to be any clicking. Check to make sure the diff isn't turning when you spin the input shaft.
Red dust is OK. But...are the input shaft splines rusty?
Old Jun 30, 2014 | 04:25 PM
Sure, but that means splitting the case and taking everything apart in order to replace the input-shaft bearing. That $20-$60 isn't worth the hassle of disassembly if you don't need to do it.
Old Jun 30, 2014 | 07:47 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
OP...the clicking is probably happening because the trans is either in gear or kind of engaging a gear.
Or you're grabbing the input shaft and turning it back and forth quickly. That shaft is loaded with gears and bearings and other doo-dads that click together as you change direction with the input shaft. Normal.
Old Jul 1, 2014 | 04:30 AM
Schister66's Avatar
Man U FTW
OP: better hope your doo-dad(s) didn't wear out...those are hard to find in the parts catalog
Hondaciv95VX
17
Dec 18, 2006 08:11 AM
calipornya
Nov 23, 2004 08:14 PM
