Where to buy clutch safety switch?
Old Jun 28, 2014 | 01:26 AM
austinramsay's Avatar
Default Where to buy clutch safety switch?
Would really prefer an oem honda one, but can't seem to find it. Anyone have a part number? Or can someone find one that will directly fit like oem? I have an '89 Si by the way.
Old Jun 28, 2014 | 02:30 AM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
Default Re: Where to buy clutch safety switch?
got one from an 89 accord lxi there are usually two, which do you need? it's probably the same
Old Jun 28, 2014 | 02:34 AM
ferio-ichi3's Avatar
Ferio Wdm Edition
Majestic honda, look up the car, and go to the pedal assembly and youll find it.
Old Jun 28, 2014 | 02:38 AM
Ferio Wdm Edition
Not the case. One is the clutch switch, and the other is the cruise control switch. They are backwards. Clutch switch button needs to pushed in to connect the circuit, while cruise control switch button disconnects the circuit. Ending cruise control.
Old Jun 28, 2014 | 04:03 AM
HondaPartsHero's Avatar
Technical Hero
35710-SE3-A01 SWITCH ASSY., CLUTCH (INHIBITER)
Old Jun 28, 2014 | 08:51 AM
actually on these some of them had a start relay that required the clutch switch to be pushed in order for the relay to energize, some of them had two separate switches also, OP I will see which one I have
Old Jun 28, 2014 | 10:21 AM
tried finding it on there but didnt see it. So that part number is correct right? It's not showing crx in the list of applications but it could just not be listed.
Old Jun 28, 2014 | 10:47 AM
OP find out if the one on your car is normally open or normally closed when the clutch is pushed, and I'll see if the one I have is the same, I know the threads etc will be identical, probably the same connector too
Bubezzy
Dec 3, 2017 03:14 PM
efyou
Oct 9, 2007 01:54 PM
binarypunk
Sep 24, 2007 06:04 PM
bossman9
Apr 14, 2007 07:13 PM
playahwitgame
Apr 19, 2006 10:37 AM
