92-95 civic trans chassis bracket
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
So long story short my hatch had a K swap and Im going back to B series.. we already welded in the new floor where the cable box was installed now we have to weld the trans bracket on the chassis .. running out to the local junk yard I can not track down any eg's to get the measurements and just wondering if there are any online sources that could help or if anyone has any info.. right now I'm trying to get my car to paint and its the last thing on the list to do before it goes!! Thanks for any help or replies
Ahh. what I did for mine was drop the swap in and mark it. Remove swap and weld. A bit more time consuming but I also could not find an eg to measure.
I did the same thing as 2fast4u831, measured a few cars as well, but it still seemed the best way was to install the swap line up the mount and then weld it
Know this post is a bit old, but if you buy the bracket from honda and just hold it up against the frame rail, you will be able to tell where it is supposed to go. Move it along the frame side to side and you it will sort of stop where it was meant to be
just to touch on this my engine bay was shaved and they grind where that mount was smooth ... you could not tell, I actually had to track a buddy down with a MT eg and get all my measurements and honestly if it was not I'd do the same regardless better safe then sorry...2fast4u831 has been great help! thanks again
CRXSIR1
Oct 2, 2015 10:23 AM
95 honda8
Aug 2, 2007 04:29 PM
