resistor in SRS and ABS circuits?
Old Jun 26, 2014 | 02:35 PM
crazyhouse2011's Avatar
Default resistor in SRS and ABS circuits?
The previous owner put an aftermarket steering wheel on this 94 LS (which i promptly replaced with a higher quality one). The SRS light is on since the airbag was removed. I know that by installing a resistor in the circuit the light will go off. Where will i find the wire to install a resistor, and what rating should it be. Also, how do i go about doing it, is it a simple solder job?
He also disconnected the ABS. Therefore, the ABS light is on too. Where in the circuit do i install the resistor, what rating should the resistor be, and where will i find the necessary wire to pull this off.
Thank you fellas.
Old Jun 26, 2014 | 03:48 PM
Boxxx's Avatar
Default Re: resistor in SRS and ABS circuits?
Remove the bulbs from the cluster?
Old Jun 26, 2014 | 04:01 PM
that would work too. Compared to the 92-95 civic dash removal (which has the driver and center vents attached to the black trim piece that is part of the gauge housing), how difficult is the dash removal on the integra?
Old Jun 26, 2014 | 05:05 PM
kaycee_00's Avatar
Two screws at the top of the black bezel around the cluster, then just the three screws holding the cluster in place and thats it.
https://honda-tech.com/forums/honda-accord-1990-2002-2/how-bypass-srs-aftermarket-wheel-2398113/
That link lists what you need if you want to use the resistor. Locations should be roughly the same.
Old Jun 26, 2014 | 05:35 PM
Boxxx's Avatar
If you go with removing the bulbs, while you're at it you could put in some white (or another colour of your choice) LEDs for the gauge faces.
Old Jun 26, 2014 | 06:16 PM
https://honda-tech.com/forums/showthread.php?t=2398113
Dude that's awesome. The civic requires you to remove the clock, remove the trim, and then remove the cluster. A lot of hassle. While i was in there though I went ahead and cut the clock dimmer wire so when i turn on the headlights the clock still stays at full brightness (for like driving in heavy rain during the day)
Old Jun 27, 2014 | 03:42 AM
silvertaxasteg's Avatar
I am SO fancy!
Caveat: As long as one is not in a state where that is required for any safety inspection. Check with local laws first.
Old Jun 27, 2014 | 03:44 AM
No worries on that here. So I see how to remove the cluster, but how do i get to the bulbs? Is there anything i need to be careful of?
Old Jun 27, 2014 | 05:52 AM
kaycee_00's Avatar
Bulbs sit inside holders that just twist in and out on the back of the cluster. There really isn't much damage you can do accidentally back there, just make sure you dont rip the green film on the back of the cluster. And if its never been taken out before you may have a clip holding the harness to the cluster that may have to be undone.
Old Jun 27, 2014 | 11:34 AM
Boxxx's Avatar
I forget those kinds of things exist, you'll have to forgive me. Yeah, in Alabama you can pretty much get away with anything which is a double edged blade in of itself.
Old Jun 27, 2014 | 02:39 PM
Okay. Got the ABS light out. But there is no SRS light, at least not on the back. There are two bulbs, one for the door light, one for the seatbelt light. I took both of em out and plugged in the yellow cable and the SRS still lights up. Where is the bulb?
Old Jun 27, 2014 | 02:40 PM
What colors look nice, and where can i get them while i have the cluster in the house
Old Jun 27, 2014 | 03:04 PM
I just bought some helladope 5 way bright *** blue LED cluster lights for 5 bucks apiece. 20 dollars shipped to my door by monday.
Old Jun 27, 2014 | 04:02 PM
Boxxx's Avatar
Nice, blue is one of my favourite colours.
Old Jun 27, 2014 | 06:00 PM
adnoh61B's Avatar
Yep just pull the bulbs.
Side note: I miss Alabama. Cant wait to come home again.
Old Jun 27, 2014 | 07:47 PM
HOW DO YOU GET THE SRS LIGHT OUT???? THERE IS ONLY TWO BULBS IN THE 3 BULB SUBCLUSTER THAT THE SRS IS IN
Old Jun 27, 2014 | 07:59 PM
adnoh61B's Avatar
Standby I will go check mine....
Old Jun 27, 2014 | 08:36 PM
adnoh61B's Avatar
Ok so since you have both lights you are trying to get off you should just be able to unplug the yellow plug on the back of your cluster.
Old Jun 27, 2014 | 09:36 PM
kaycee_00's Avatar
That yellow cable you plugged in is the srs lead for the cluster. Leave it undone and you shouldn't see the light come on anymore.
Old Jun 30, 2014 | 03:47 AM
I am SO fancy!
Click this link. You'll find all you need to know.
SLURS
Oct 30, 2009 01:50 PM
news_watch
Feb 3, 2009 04:18 AM
JimmyAtlantis
Dec 8, 2005 08:51 AM
1997GS-R
Sep 29, 2005 05:12 PM
CXHatchback
May 8, 2003 07:36 AM
