94 Accord truhart coilovers.
I've never heard of them.
Biggest problem with 'cheap' C/Os is the spring rate/quality are unknowns, as is the dampen rate/quality of the shocks.
If your going to C/Os you are more than likely going to be goofing with your suspension a bit, if this is the case, at minimum get a Ground Control/Koni system.
On the flip side uber expensive systems can be overpriced.
Workin! Actually, idk jack about this company. I bought the coilovers when there photo's were good, as a test for quality. Every bit has been exactly as it should, and I'm still checking wear/leaks regularly, but haven't seen any. I'm pretty happy with my purchase.
Just a note: I am not contracted or paid in any way by this comment. You are getting an honest review of their product.
https://www.facebook.com/TruHartUSA
My only problem was they weren't quite that high.
SEE:
At the highest you could go w/o preload. Well, maybe you could, I like to run ~1" of lower unit thread, to make sure it is safe. They told me not to run preload on the springs, and I did, because f'it, I feel I know more then them.
gotta add this bit:
see the mirrors in my top photo, I added those :D
they work.
they were inspected by the DMV, and legal.
they are -STOCK- Honda mirrors!!! from a motorcycle (Hornet 600, 599, CB600-F6) :D
fit with parts for house water pipe :D
JDM***CD6
Feb 12, 2010 07:31 PM
EG-SIXV-TEC
13
Sep 20, 2009 09:22 AM
