Rear shock body stuck on F/F T1's
Old Jun 24, 2014 | 07:53 PM
B_Swapped93's Avatar
Default Rear shock body stuck on F/F T1's
Before the thought of them being all gummed up NO these things are damn near new! no grim on the threads at all. The issue is the shock body seems to be stuck and all that's spinning is the 2 upper collar rings and ******* with the preload, I tried taking the preload off the springs and the shock body still won't turn. For ppl wondering this is a "full body coilover" what I circled in orange keeps turning no matter what, the body it's self is stuck I put tons of WD-40 on them even but they look like the ones in the photo...new. I've made sure both lock rings are tight when trying to get the body to move.
Old Jun 24, 2014 | 08:20 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: Rear shock body stuck on F/F T1's
Don't take this as an insult. I have to ask. You loosened the bottom collar first, right?
Old Jun 24, 2014 | 08:29 PM
yes the perch collars are almost of the body at the moment, that's after I took the preload off them. for some reason the thing is stuck.
Old Jun 24, 2014 | 08:32 PM
B serious's Avatar
I'm not sure what you mean. I was referring to the bottom collar. The one that locks the body. Not the two that lock the spring. Did you loosen that? None of this has anything to do with preload, BTW.
Old Jun 24, 2014 | 08:40 PM
B serious's Avatar
That was it, wasn't it? The bottom collar was still tightened?
Old Jun 24, 2014 | 09:23 PM
the little shock body lock ring was loosened good every attempt I made, I meant the coilover is almost disassembled as I've maxed the upper perches almost off the shock body.
when the shock body stays still and you're compressing the spring only that's preload. Which is what's happening here the car was bouncy when I had the thing all the way down then I raised the perches only with the shock body staying still, making it solid as ****.
Old Jun 25, 2014 | 03:56 AM
B serious's Avatar
Wait....so this whole time you were lowering and raising it by lowering and raising the spring perches? I don't understand....
Why?
Do you have them off the car or are they still on the car? I would do this while they're assembled and on the car:
Jam the (top two) spring perch collars together like crazy.
Loosen the very bottom lock collar (the singular one)
If you're trying to turn the shock body UPwards:
put one spanner wrench on the bottom one of the two top collars (stay with me) and turn the wrench counterclockwise looking from the top. It'll move.
If trying to move the shock body DOWNwards:
Put the spanner wrench on the top most collar and turn clockwise looking from the top.
I usually put a dab of anti sieze on those threads to prevent the sticking, BTW.
Old Jun 25, 2014 | 08:27 AM
ok i'll give that a shot, always WD-40'd them when I was down there the threads look good just the thing is stuck.
Old Jun 25, 2014 | 09:26 AM
B serious's Avatar
Lmk how it worked out. On those coilovers, you're supposed to use the shock body to adjust height...not the spring perches. The point being that you maintain 100% shock travel while lowering the car.
Old Jun 25, 2014 | 01:01 PM
it didn't work and yah the front are fine but for some reason the rears are stuck, worth taking them off and bringing them to a garage ?. maybe they need to be heated ? afaik there is no gas it in bottom part or at least the red part that the body screws in.
Old Jun 27, 2014 | 01:44 PM
bump seriously no one wants to buy my stanced teg....
Old Jun 28, 2014 | 06:43 AM
bump....
Old Jun 28, 2014 | 06:58 AM
B serious's Avatar
Are the assemblies still on the car? Why did my method not work? What happened when you tried it? Help us help you.
Old Jun 28, 2014 | 07:49 AM
yes they're on the car bolted in tight. The perches just moved(preload) like last time the collars are tight together so the 2nd wrench held by my left hand just turned as my right is obv stronger, actually what it was doing was separating the top perch rings.
Old Jun 28, 2014 | 08:30 PM
B serious's Avatar
If you're seperating the perch rings, you did it wrong. My method will force the two together. You ever installed or taken a stud out using 2 jam nuts? This is exactly the same principle.
You trying to move the body up or down?
Old Jun 28, 2014 | 09:59 PM
they never separated, but I'm saying the bottom lock ring being held still when you're trying to spin the top counter clock would in theory be separating them. But my issues remains just the preload gets messed with, soaked them with wd-40 even got some in from the bottom the threads are clean tho barley any grim even before all this. I was trying to get them up yes I know the only last thing I could think of is locking the 3rd and final ring against the top 2 perches...
Old Jun 28, 2014 | 10:05 PM
B serious's Avatar
You'd be spinning the middle one counter clockwise to move the shock body upwards. Not the top. They would just keep jamming together more if you did that. They would not seperate.
Unless you're saying that the two top collars just spun upwards together and moved away from the bottom one.
And yes...you can use the bottom one as a 3rd jam nut.
Old Jun 28, 2014 | 10:34 PM
ok i'll give that a try making sure it stays on the middle perch, no if I do it from the top collar the preload just gets messed with. it's the smallest may not do anything it's just a bit bigger then the shock body.
rhennin
Suspension & Brakes
Apr 7, 2007 07:11 PM
XYU
Aug 24, 2006 02:53 PM
Dorikamu
Jun 25, 2003 12:22 PM
