B18b1 ticking
Old Jun 24, 2014 | 07:18 PM
ShakeTheEarth's Avatar
Icon2 B18b1 ticking
I have a 96 Acura Integra with a b18b1 LS and I started to hear a ticking noise a few days ago. It sounds like its coming from around the timing belt area. Its not very loud, only noticable when im idling. It does get faster when i accelerate but not louder. Im not having any idling issues and my car performs like normal. Does anyone have any idea what it could be?
Old Jun 24, 2014 | 08:43 PM
crazyhouse2011's Avatar
Default Re: B18b1 ticking
Just the valves ticking. You need a valve adjustment. Isn't terribly hard, just a bit time consuming. Look up a youtube video on valve adjustment
Old Jun 24, 2014 | 09:44 PM
NotARaCist's Avatar
I never narc'd on nobody!
What the actual hell makes you think this is the Integra section?
Old Jun 25, 2014 | 04:13 AM
lol OP did something wrong! LETS GET HIM!!!
Old Jun 25, 2014 | 04:37 AM
Don't yell at me
Old Jun 25, 2014 | 05:09 AM
NotARaCist's Avatar
There are separate sub forums for every model and year range. Please do everyone a favor in the future and make sure you're posting in the right one.
That said, you probably need a valve lash adjustment.
Old Jun 25, 2014 | 05:41 AM
Former User's Avatar
Moved to the Integra forum.
Old Jun 25, 2014 | 05:42 AM
ekhatch1227's Avatar
Making him cry.... shame on you!
Old Jun 25, 2014 | 05:47 AM
That's what I thought but wasn't 100%. And I didn't see the integra forum at first so I went with the next best thing. Sorry.
Old Jun 25, 2014 | 05:51 AM
Also will it hurt to drive it? I have to get to work but it won't be more than 10 miles I'll be able to get to adjusting it tomorrow.
Old Jun 25, 2014 | 08:09 AM
kaycee_00's Avatar
You'll be fine. Just make sure the motors cold before you adjust them tomorrow.
Old Jun 25, 2014 | 08:53 AM
Thanks.
Old Jun 25, 2014 | 09:44 PM
Update, was driving girlfriend to her class and went to show a friend the ticking. Popped the hood and started the car and there was no ticking. Got all the way home with no ticking and was really confused about the whole thing. Started the car later to go fishing and still no ticking, got to the gas station and heard it again. Kept clicking from the gas station to the fishing spot, then from there to a red light and didn't hear the ticking anymore. When I got home it was ticking again, thoughts?
Old Jun 26, 2014 | 04:25 AM
kaycee_00's Avatar
Is it a rapid ticking? It might just be the injectors your hearing. I would still adjust the valve lash if you haven't done that recently and see if the noise is still there after.
Old Jun 26, 2014 | 08:42 AM
I will still do the valve lash but I wouldnt say its a rapid ticking. When I'm idling it ticks with the lobe of the motor and speeds up when I accelerate but doesn't get louder like when I'm driving I cant hear it at all. My buddy said it could be a belt?
Old Jun 26, 2014 | 09:32 AM
kaycee_00's Avatar
Belts dont tend to tick, when they get worn they usually just squeal or break. After you do the adjustment try to get a recording of the ticking if it doesn't go away.
Old Jun 26, 2014 | 01:49 PM
i have a video of it now, and also i think i found the problem. While checking under the hood again i hit the throttle and saw some exhaust escape from the header near the head on the side where i was hearing ticking, going to replace the gasket and see if that works. Still going to do the valve adjustment just not right away i dont have the time this week. Will update when gasket is changed. I'll post the video if i can ever figure out how.
Old Jun 27, 2014 | 08:09 AM
Tight-R's Avatar
That could be the ticking. As it heats up it might even seal the leak.
Old Jun 27, 2014 | 02:14 PM
as it heats up it gets worse. cold start theres no ticking and as it heats up im guessing the gasket pushes out the header and you can hear the valves.
Old Jun 29, 2014 | 12:28 PM
Replaced the gasket and fixed the exhaust leak but it still ticks, could it be the air compressor? Its coming from the lower side of the engine around the belts and ****. I've read other threads on here saying it ticks when its about to go out but still not sure.
Old Jun 29, 2014 | 01:29 PM
m4xwellmurd3r's Avatar
Pop off the accerssory belts after it warms up and see if the noise goes away. Dont run it long cause you'll kill the battery
Old Jun 29, 2014 | 06:36 PM
Will this tell me its a pulley? And if so whats the worst thing that can happen if i keep driving on it?
4gen
Sep 14, 2015 12:06 PM
scartail
Apr 12, 2007 04:20 AM
iloyola
Jul 27, 2005 01:53 PM
MODsjtown
Jan 4, 2005 01:05 PM
quickLSt
Jul 24, 2001 07:14 AM
