eg turbo k swap partout 5 lug jdm
NEW PRICES......MAKE OFFERS. Getting out of hondas for now everything has to go.
Hey ht, decided to part out my 95 hatch. Have other plans right now in life and unfortunately have no time or money to put toward the car anymore. I will be constantly updating the thread with parts. Currently the car is completely stripped and parts are ready to go. The shell is currently spoken for and pending payment. If that falls through then I will update the thread with it for sale. Please if you are going to contact me either have the money or reasonable trade. Don't waste my time or yours. If seriously interested i can give my number out. All prices are best offer and do not include shipping or paypal fees. Ok so Enoughs enough, Now onto the parts.
K24a4 motor(no vc, manifolds or oil pan.)...sold to chero112
K20z3 civic si 6spd lsd trans.......Sold to speedfreak44
Vacuum block new.....sold local
Innovative k series Fuel rail......sold to speedfreak44
aeromotive fuel pressure regulater......sold to speedfreak44
Rc 1000cc injectors with clips new.....sold to 316k20eg
Breather catch can setup with k series valve cover wrinkled black comes with a/n fittings and braided hose new......sold to 316k20eg
RBC Manifold shaved and wrinkled black......sold to speedfreak44
Rsx-s throttle body with newer sensors and adaptor plate....Sold to speedfreak44
Aluminum half rad new with slim fan.......sold local
Fal slim fan with shroud(red)........60
K20a2 02-04 engine wire harness.....sold to speedfreak44
K20a2 charge harness.........Sold to speedfreak44
Sparks conversion harness with instruction booklet......sold to speedfreak44
K20z3 Starter......sold to speedfreak44
K20z3 Alternator......50
K20z3 Half shaft......50
K20z3 oem injectors.....10
Russell in line fuel filter with hose and fittings......40
Honda injectors resistor box.......sold
Hasport Motor mounts and brackets with 95a inserts.....sold to speedfreak44
Rsx-s Shifter cables......sold to speedfreak44
Rsx-s 6spd shifter box with short shifter.......sold to speedfreak44
Rsx-s 6spd shifter mechanism.......sold to speedfreak44
Rsx-s shift cable bracket......sold to speedfreak44
Crv engine mount needed for k24 swaps.....sold to speedfreak44
Karcepts Shifter box mounting kit(had to make a clip for the one side because it was shipped without it originally. Worked and lined up perfect)........sold to speedfreak44
Aftermarket Coolant over flow tank........15
10 gal fuel cell sumped with fittings and some braided line.....60
Turbo kit (everything in this kit is brand new other then the wastegate, which was only ran 5 times on a previous kit)
would like to sell as a complete kit.......sold to 316k20eg
Full race garret T3t67 70ar turbo*journal bearing
Rld fab k series sidewinder manifold*with t3/t4 flange option
4" uppipe
Wastegate Dump tube
Tial wastegate 44mm v band*
vertical flow Intercooler*with 90s off of end tanks
Custom charge pipes 2.5" with rfl blow off valve
clamps and couplers
Turbo smart manual boost controller*
Turbo blanket*
Steel Kseries oil pan tapped
Oil return line
Autometer carbon Boost gauge*......sold to tegger93
Autometer carbon Oil pressure gauge*.....sold to tegger93
Autometer carbon Water temp gauge*......sold to tegger93
Charge pipes, uppipe, Dump tube, and all fab work done by Ron at rld-fab. Work is top notch. He also made the flange setup for the rfl bov and modified the bov so that it won't leak.
Jdm itr 36mm complete 5 lug setup*(rotors, pads, e brake cables, trailing arms, front knuckles, etc.)........sold
Jdm itr 1" master cylinder and brake booster......sols
5x114.3 sport edition 15" wheels some light scratching from storage new).....sold local
spoon replica front lip*(new, mounted never saw the road)....sold local
Custom front aluminum Splitter*that I made(Aluminum blade and galvanized steel brackets with hardware)......100
H&r springs with koni yellows......150
Jdm type r front sway bar...40
srr rear tie bar and sway bar(sway bar needs end links).....50
Srr rear lower control arms(purple)......50
Jdm bronze Hatch glass with jdm parking stickers with Cf duckbill (duckbill has fading)......120
Jdm eg6 steering wheel......100
Recaro srd seats with rails (small cut on passenger seat near shifter, and missing a reclining ****).......sold local
Rc51 digital cluster and harness (rvt1000r)......125
Integra rear seat(upper and lower).....25
Integra front console arm rest......15
Jdm ek9 ctr red front floor mats very dirty and worn......25
92-95 civic sedan oem corner lenses (one broken tab)....5
If there isn't a pic up yet then pm me and I can get one to you. Everything will be posted up with pic/name card as I update the thread
4" uppipe
Wastegate Dump tube
clamps and couplers
Turbo blanket*
Oil return line
Rbc, shifter plate, fpr, fuel rail, and conversion harness sold to speedfreak44.
Make reasonable offers on parts. Cash or trade
Water temp/boost/oil psi gauges sold to tegger93
Starter and Crv engine mount sold to speedfreak44
Make offers I want this stuff gone
I've had a lot of interest in the 5 lug setup. First 600 shipped+paypal fees takes it. I will include the wheels I have for cheap
Ttt
Recaro srd seats 400 with free mounts and sliders. Will meet half way if not to far for additional cost if needed. Want these gone
