has anyone used the speedfactory drag radiator?
Old Jun 24, 2014 | 08:52 AM
Type_R_Crx's Avatar
Default has anyone used the speedfactory drag radiator?
Like the title states has anyone used the drag radiator in there car not only for drag racing at the track but on the street aswell? I just want to know how the cars temperature holds up compared to a half size eg radiator? Thanks in advance. ...
Old Jun 24, 2014 | 12:42 PM
hondatech8798's Avatar
Default Re: has anyone used the speedfactory drag radiator?
I'm curious aswell
Old Jun 24, 2014 | 03:15 PM
Type_R_Crx's Avatar
Thanks bump
Old Jun 24, 2014 | 05:39 PM
COM2's Avatar
Have you tried contacting them directly? In my dealings with them, I have found that they are quite helpful when you contact them about there product. Let them know your set-up and your use for the car and they will point you in the right direction. I am not associated with Speedfactory other than being a long time customer. Email or call them and I'm sure they will be glad to answer your questions.
Old Jun 25, 2014 | 10:08 AM
V-SPEC 1's Avatar
If my memory serves me correctly, they told me that it will work on street cars. But I'm sure it depends where u live. Hotter states like Florida if u daily it in a turbocharge application, I'm not sure if it can handle it.
Old Jun 25, 2014 | 04:23 PM
KevinEF7's Avatar
Says right on there website it is designed for street cars aswell and is more efficient than a half sized stock rad
Old Jun 26, 2014 | 07:20 AM
Dark_Teg's Avatar
I am definitely using that in my new build.
Old Jun 26, 2014 | 11:44 AM
Twenty47's Avatar
i have it on my race car and have never had a cooling problem. its never seen the street bu its seen 100+ degree texas heat with not so cool burning fuel and never went above like 180 on the return road.
I actually have the first one ever made
Old Jun 26, 2014 | 11:51 AM
neonkid's Avatar
I have one on my car and i took my car out on the street the other night and temp was perfectly fine.
Old Aug 29, 2014 | 10:41 AM
Type_R_Crx's Avatar
Bump thanks for all the feed back... looks like imma have to go with that radiator... and you guys that commented above, do you guys have the shroud and fan combo they offer or you guys put your own on?
Old Aug 30, 2014 | 10:28 AM
V-SPEC 1's Avatar
You can build your own if you like. Probably save u some money.
Old Aug 30, 2014 | 06:40 PM
1HGEJ2's Avatar
Where can i buy watercore?
Old Aug 30, 2014 | 06:52 PM
redboost10's Avatar
Ron Davis makes some very nice radiators
Old Aug 31, 2014 | 05:04 PM
V-SPEC 1's Avatar
bell intercooler I think sells them.
Old Jul 9, 2015 | 12:45 PM
Steeve_Civic's Avatar
Do you have some others feedbacks?
Thank you
Old Oct 10, 2016 | 04:39 PM
gutted-dx's Avatar
I know this is an old thread but has anyone else used this radiator with luck on the street? I'm having a hell of a time keeping my turbo B16 sub 200 with the bumper on.
Fluidyne half radiator
Oem thermostat
S300 set to 185f
The radiator is slightly clocked towards the headlight because of the compressor housing and I think that's what's causing thr overheating. The SF is narrow enough that I could face it foward. All help is appreciated.
Joe
forthrills
Welding / Fabrication
Sep 22, 2010 10:16 AM
msmotorsports
Oct 1, 2005 02:33 PM
pumafeet10
Jun 2, 2005 02:59 PM
Mikey3000
Sep 13, 2003 02:21 PM
