Deleting factory 94 gsr oil cooler
Looking for some help on deleting these oil cooler, The factory one that has coolant lines looping around onto the oil sandwich plate. Deleting it for a golden eagle sandwich plate so my turbo feed and oil psi gauge can go directly to the plate. There's a piece coming out the block where the coolant hose went from the sandwich plate to that. I want to know if there's a part I can get from honda that will delete that. Like a sealing bolt or plug of some sort.
The 2 bigger holes to the left and right goto my catch can, The fitting coming out the block right above the right hole is what I'm trying to replace with a bolt/plug to remove it all together. (Sorry if i've repeated myself i'm just trying to be clear as to what i'm talking about.)
Ordering last few gaskets from honda (hopefully) for my motor rebuild and wanting to get that bolt when I do if there is one.
Quick motor pic, CP Pistons 9.8:1, CP Upgraded wrist pins, Brian crower ARP 625+ rods (1200hp capable), micropolished/balanced crank, ACL race bearings clearances right at my target specs, rotating assembly is assembled..
Thanks for any help guys
Well after more searching I found out a transmission sealing bolt off of certain honda's will fit
90083-PG1-000
m16x1.5
Happen to have one in my bolt drawer. Whenever I sell my dirtbike or streetbike I'm going to get the teg closer to done.
90083-PG1-000
m16x1.5
cluelessmale
13
Oct 25, 2012 06:28 PM
JDM_SOHC
17
Nov 2, 2009 05:01 PM
275Performance
May 5, 2004 11:30 AM
