B18C1 built motor
What I have here for sale is a a professionally fully built b18c1 swap with the numbers matching gsr transmission (that has oem type r lsd with 4.7 final drive installed the same time the long block was built) This is NOT a backyard built swap. This is a 2001 b18C1 with 62,221 miles BEFORE the build. It has just under 5000 miles on it since the completion of the build, I have decided to sell this cause i'm moving onto the next project so I no longer need this built swap.
Produces 223 WHP with 150 WTQ
There's more power to be made with this swap with better cams. This is a 12 sec all motor swap as it sits now.
Head-
New bronze valve guides with tapered ends
skunk2 valves
skunk 2 valve springs
skunk2 pro 2 cams
5 angle port and polish
skunk2 Intake manifold
Aem high flow fuel rail
Injector Dynamic 1000 cc injectors( so that I do not buy another injectors when I go for more power with this set up)
Inline four 70 mm throttle body
Block-
fully balanced rotating assembly:
race balanced crankshaft and flywheel (yes, the fly wheel was balanced as well)
the block was honed and posted (google block posting for more details)
stock bore 13.1 wiseco pistons mated to K1 H beam rods (both are forged assembly, lighter and stronger than oem)
ATI crank pulley
Fidanza 9 lbs flywheel
clutchmaster fx400 ( just broken in, around 500 miles on it now)
The block was honed and measured for precision build, this whole swap was built with precision. This swap was built to rev and make power to 10,000 rpm. It is tuned on E85 on crome and will come with the p72 ecu with the chip and the tune. This is truly a turn key swap, throw the swap into your shell and plug in the ecu and fill the tank up with E85 and have fun with it.
DYNO CHARTS AND THE BUILT SHEETS WILL BE PROVIDED.
The entire swap including the transmission has been painted black.
This ENTIRE swap came out of my 2001 GSR with 62,221 miles on it
NUMBER MATCHING GSR TRANSMISSION WITH JDM TYPE R OEM LSD WITH THE 4.7 FINAL DRIVE. NO GRINDS OR POP OUT WHATSOEVER.
SERIOUS BUYER only, please! I do not want to hear " I'll have the money when I get paid next week" MONEY TALKS , BULLSHIT WALKS ... PLEASE DO NOT WASTE YOURS AND MY TIME.
I feel that what I am asking for this swap is VERY reasonable with the way it sits, $3500. Once again, this swap has 0 problems , 0 issues with it .. you will not be scammed or cheated out of your money with this swap.
Anyone from out of the state interested in this swap, you better be prepared to come and pick it up personally and/or pay for this ON MY TERMS to buy this swap from me before I take you seriously.
Any questions that wasn't already covered in this ad, I can answer them through texts, PM or emails , Pics can be provided upon request. Thanks for looking.
Head-
skunk2 valves
skunk2 pro 2 cams
Block-
ATI crank pulley
Bumping this up till this is sold ! Reasonable offers will be considered seriously. LOTS of money went into building this swap and tuning it and It does truly have less than 5000 miles on it
LOOKBEHINDU
Northeast (Sales)
12
Nov 1, 2012 07:10 PM
thisisareallylongusername
Nov 4, 2011 12:11 PM
