Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
No lower brake lights, other lights work fine 99 TL
Old Jun 23, 2014 | 02:20 PM
blinkhonda's Avatar
Icon2 No lower brake lights, other lights work fine 99 TL
Hi folks. 99 Acura TL. Replaced all bulbs for brake lights. When hitting the brake, the lower lights (in the tail light cluster) do not activate, but the light on the console (in the back window) works fine. All other tail lights are fine; running lights, reverse lights, turn signals. Only weird thing is that we've gotten a ton of rain over the last few days, but otherwise nothing has changed with the car. Any ideas? Thanks a lot!
Old Jun 29, 2014 | 08:15 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: No lower brake lights, other lights work fine 99 TL
The power for the left and right brake light bulbs goes through the brake light failure sensor, while the high mount brake light does not go through the brake light failure sensor.
The brake light failure sensor is located in the left rear of the trunk, next to brake/taillight socket. The harness connector for the brake failure sensor is a separate 6 pin gray connector. Disconnect the 6P gray connector for the brake light failure sensor. With a small wire, jump the 6P connector cavity terminal (where the Wht/Blk wire is) to the cavity terminal (with the Grn wire). The Wht/Blk wire is a wire with white insulation and a black stripe running through it. Depress the brake pedal; does the left and right brake lights work? If they work this way, you probably have a faulty brake light failure sensor.
Old Sep 28, 2014 | 02:29 AM
thai206's Avatar
^what he said. But check bulb for license plate. Sometimes little things like that can disrupt the flow of things and cause headaches. Happened to me when after replacing all bulbs and still had "brake lamp" on dash and front turn lights would come on everytime when I brake. Found out bulb in rear license plate wasnt seated properly and once corrected it solved all issues.
delgato
Jan 12, 2021 07:27 AM
Nderuso
Dec 30, 2019 08:43 AM
AcuCrazy
Oct 28, 2008 11:27 AM
AndyD
Feb 18, 2008 11:09 PM
rbflurry
Jan 18, 2006 08:56 PM
