Updated: Drag Car Partout. Plenty of parts listed!
Old Jun 22, 2014 | 03:42 PM
nostreble's Avatar
Default Updated: Drag Car Partout. Plenty of parts listed!
Parting out our project drag car. Open to reasonable trades.
Located in Carson, California 90746
Call or text
424 731 2162 JR
424 242 5808 Rod
*Chassis: $2000
1995 Honda Civic Coupe (Title in Hand)
-MB Products 1pc Fiberglass Front End
-Strada Fiberglass Doors
-Brand new Custom Lexan all around
-Custom Lexan Sunroof Plug
-Custom Rollcage
-Wheelie Bar
-Fresh Paint Job
2-stage (outside)
Single stage (inside)
-Brand new AC Autotechnic Rear Bumper Diffuser 1pc.
-Antenna Block Off Plate
-Brand new Bushings Installed:
Energy Suspension Hyperflex Bushing Kits 16-18103G
Energy Suspension 16.7106G Rear Right Trailing Arm Set
-Newly Rebuilt Rear Brake Drums:
Bendix Brakes 576 - Bendix Brakes Brake Shoes
Bendix Brakes PDR0508 - Bendix Brakes Global Brake Drums
Dorman HW17307 - Dorman Brake Hardware Kits
*$3500 for Longblock (willing to part head for $1000 & shortblock for $2400)
LONGBLOCK: Motor has 0 miles since rebuild. Has new gaskets, seals, rings, OEM water pump, OEM timing belt, etc.
1999 GSR Block (VIN # upon request)
-AEBS T-Sleeves Solid Deck w/ Copper O-Rings (Done by AEBS)
-JE 84mm Pistons w/ Ceramic Coated Tops Nitrile Coated Skirts Straight Wall
-JE Pro Seal Rings (NEW)
-Pauter Chromoly Rods (Standard GSR Length) (ARP 2000 Hardware)
-AEBS Main studs
-ARP Head studs
-Stock GSR crank w. micro polished journals & cryo treatment (Standard clearances)
-AZ Billet Aluminum Race Girdle for Main Caps
-oil pan (does not come tapped)
1997 USDM ITR B18C5 Head
-Cometic Head gasket
-5 Angle Valve Job
-Deshrouded Valve Ports
-Mild Port/Polish
-Supertech Valves (.05 oversized): Nitride Coated Intake Valves, Iconel Exhaust Valves
-Buddyclub Dual Springs
-KMS Titanium Retainers
-KMS Valve Seals
-Stock ITR Cams
-Skunk2 Cam Gears
-AEBS Billet Aluminum Cam Seal
-New A2 S/S Socket set screws and serrated flange nuts for Exhaust/Turbo Manifold
*$800- Driveshaft Shop DSS Level 5 Axles and Hubs w/ New lower ball joints and New bearings (Passenger hub may need replacing)
*$800- Garrett GT3582R Turbo w/ .63 AR Exhaust Housing
*$250- Brand new Synapse Synchronic Universal 44mm V-band flange with 50mm valve Wastegate in Black w/ Flanges and Clamps
*$150-1000cc MSD Injectors (Resistor Box required)
*$1100- Brand new Clutch Masters FX700 Twin Clutch Kit (Installed but never used) comes with OEM flywheel bolts torqued down once
See link: http://www.maperformance.com/clutch-...8-913-td7.html
*$80- Brand new Hawk Performance HB245N631 HP Plus Brake Pad Set w/ OEM DC Calipers
Old Jun 26, 2014 | 04:55 PM
nostreble's Avatar
Default Re: Updated: Drag Car Partout. Plenty of parts listed!
Ttt
Old Jun 27, 2014 | 06:53 AM
jdmpro23's Avatar
DO NOT BUY FROM THIS BITCH!!! SCAMMER!!!!!
Old Jun 27, 2014 | 10:51 AM
iaintnogangster's Avatar
Werent you the guy who CAME in person to check out the set of wheels, then one week later claimed it was BENT BEYOND repair?...let me ask you this...were you that blind to see a bend beyond repair when you came in person? Cuz im sure if it was bent beyond repair you would be able to see that bend...
BUMP FOR LEGIT SELLER!!!
Old Jun 27, 2014 | 11:25 AM
FeelTheBass's Avatar
Hawk Pads + DC Calipers are front + rear? Or just front?
Old Jun 27, 2014 | 02:39 PM
jdmpro23's Avatar
Were you the scumbag who repowder coated the rims to hide the damage? And I notified after 2 days. If you read your sell out of a buddy's ad it specified that the rims were mint. THAT MEANS NO BENDS, CRACKS, ETC. Get your facts straight!!!
Old Jun 27, 2014 | 03:00 PM
Werent u the guy that came to see the rims in person and had the chance to inspect the overall product before you bought it?...stop lying man...u bent the rim and tried to cash in and lie...like i said you must be blind or just a dumbass to not see a non-repairable bend...im sure everybody agrees with me..
Bump this to the top!
Old Jun 27, 2014 | 07:07 PM
nostreble's Avatar
fronts only
Old Jun 27, 2014 | 08:01 PM
toyomatt84's Avatar
Sanji
Please see here: http://hondamarketplace.com/announcement.php?f=59&a=44
nostreble
May 14, 2014 01:16 AM
nostreble
May 12, 2014 09:18 PM
nostreble
May 6, 2014 12:05 PM
nostreble
May 4, 2014 04:54 PM
Eighty-Nyne
30
Jun 12, 2009 10:34 PM
