can running rich after timing belt adjustment
Old Jun 22, 2014 | 12:45 PM
danielc2155's Avatar
Default can running rich after timing belt adjustment
Hi guys I put a b20v in my car which had a high idle. I adjusted the idle screw, fitv and throttle stop. It then idled properly and fitv was working perfectly. The afr at idle was 14s.
I checked the timing with a timing light and with the distributor fully retarded the engine was still advanced.
I did some research and came to the conclusion that the belt had jumped.
I got everything to tdc and retensioned the belt. Started the car and now it idles poorly with afrs in the 9s, black smoke the works.
Would the fitv and throttle stop adjustment make a car run rich?
I dont know where to start with the troubleshooting. Any ideas?
Old Jun 22, 2014 | 01:26 PM
grumblemarc's Avatar
The Grumpiest
Default Re: can running rich after timing belt adjustment
You put a B20 into a Datsun 260z?
Old Jun 22, 2014 | 01:35 PM
260z are cool but no ek civic
Old Jun 22, 2014 | 01:45 PM
The Grumpiest
FITV would not cause you not to be able to set time.
Might want to mention ALL mods instead of making people guess.
Old Jun 22, 2014 | 11:27 PM
holmesnmanny's Avatar
Did you jumper the service connector when you originally tried adjusting ignition timing ?
chipper
10
Jul 4, 2013 10:59 AM
Meraut
May 8, 2013 09:43 AM
violarules
Mar 18, 2008 10:53 AM
211811518
Sep 13, 2006 06:33 PM
spyderracing
Aug 27, 2004 08:39 AM
