Bleeding times? Integra
Old Jun 21, 2014 | 04:48 PM
slow_low_eddie's Avatar
Default Bleeding times? Integra
Okay so question, I'm bleeding the brakes on my 1991 Integra. My question is for example if I pump the brakes and hold it for 5 times, do I have to do it for every tire? Or do I just pump them and hold until I see pure liquid being squirted out?
Old Jun 21, 2014 | 05:44 PM
B_Swapped93's Avatar
Default Re: Bleeding times? Integra
hold it ? you generally bleed all 4 in the correct sequence pump a few times>close bleeder scew>fill BMC>pump to get the pedal stiff...then repeat the above.
Old Jun 21, 2014 | 05:51 PM
98clover's Avatar
You do it for every tire
Old Jun 21, 2014 | 10:40 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Pump the brakes several times till the pedal is stiff.
Hold the brakes down.
Someone opens the screw (brake pedal falls...hold it down)
Someone closes the screw.
Repeat from step 1.
A bunch of times. For each wheel. Keep the fluid full during all of this.
Or use a speed bleeder like a human being.
Old Jun 23, 2014 | 02:50 AM
m4xwellmurd3r's Avatar
I use one of those hand vacuum pumps from autozone/harbor freight/any cheap parts store.
Had to tear it down and re grease the orings in it cause I pumped gas into it once by accident but it still worls great
7rrivera7
12
Jul 14, 2009 06:39 PM
eumoria
Jan 29, 2008 03:38 PM
Nocturnal
Aug 2, 2005 01:07 AM
bOOsTiNSoHcVtEc
May 18, 2004 05:06 AM
GQ Cowboy
Jul 12, 2002 12:24 PM
