S300 - Car runs different when I enable B5 for datalogging
Old Jun 21, 2014 | 04:43 PM
g2turbo's Avatar
Default S300 - Car runs different when I enable B5 for datalogging
I've wired up a manual switch for datalogging on my S300, and its working... but the car runs different once I switch on the B5 (ground).
I tapped into B5 at the ECU... maybe I should just cut the original wire and have my switch the only wire coming into B5?
The car actually leans out a bit (not dramatic) when I hit the switch now... as if computer is trying to accomodate for the AC running or something.
Any ideas? I can share a datalog that I started manually (with my laptop)... then I hit the B5 switch.
Old Jun 21, 2014 | 05:01 PM
g2turbo's Avatar
Default Re: S300 - Car runs different when I enable B5 for datalogging
screenshot of the datalog.... I started this on my laptop... then flipped the B5 switch I wired up (simple groud switch)
As you see, the timing goes from 16-17 immediately to 19
The A/F also temporarily leans fattens up, then leans back out to the proper range.
Bizarre, i'm sure its something simple, looking for some input
Old Jun 21, 2014 | 05:19 PM
Muckman's Avatar
Moderator in Chief
Does battery voltage change when you flip the switch? And does the idle return to normal of you flip off the switch?
Old Jun 21, 2014 | 05:23 PM
g2turbo's Avatar
Damn your fast Brian, haha. The voltage remains solid/consistent at 13.87-13.96
Yes, once I turn the switch off the car returns to normal
Old Jun 22, 2014 | 04:26 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Guys , you are switching the A/C manually. If you have A/C then change your pinout. If you don't then disable all A/C controls in SManager and you can leave the wire as is. I personally just have tons of extra pin outs on hand so I can just pull the wire from the factory harness and solder my input to my spare pigtail. Not as clean, but I am a huge stickler for factory uncut wiring.
JDM97R
Sep 13, 2010 09:05 PM
underpressure02
Apr 23, 2007 08:42 AM
RCautoworks
Audio / Security / Video
Oct 13, 2003 03:08 PM
Pengo
Mar 17, 2002 10:05 AM
