Power steering leak on 02 Accord
Old Jun 21, 2014 | 11:19 AM
free_money's Avatar
Default Power steering leak on 02 Accord
I've had a very slight leak from my power steering pump over the last few years. I've never had any fluid dripping from the pump. There's only been dust and dirt accumulate around the pump and stick to the seeping fluid. Just today I noticed the power steering fluid was below the lower level. My power steering works great but I was wondering if there is any easy fix to stop this leak. Wasn't sure if there are seals I can replace or if the entire pump would have to be replaced.
Old Jun 21, 2014 | 11:21 AM
free_money's Avatar
Default Re: Power steering leak on 02 Accord
Here's a closer up shot of the madness!! I can't get the pictures to rotate so if you turn your head to the left it will be the correct orientation.
Old Jun 22, 2014 | 04:40 AM
Lost Again's Avatar
A few choices here.
1. Live with the small leak until it gets really bad.
2. Rebuild the pump yourself. These are pretty simple pumps and rebuild pretty easy.
3. Get another pump from a parts store or bone yard.
Old Jun 22, 2014 | 05:47 AM
free_money's Avatar
Are there any write ups anywhere to show the rebuild?? I saw a write up for a 98-01 Acura Integra which looked pretty similar to my pump but wasn't sure if it's the same or not. I'd like to rebuild it if possible.
Old Jun 22, 2014 | 07:02 AM
Lost Again's Avatar
You can get a service manual for ~$22 and it will show the steps and spec's.
Couldn't find anything online, didn't look long, for the 6th gen ps pump but did find this for a 7th gen: http://www.hondaaccordforum.com/foru...-accord-57704/
Old Jun 22, 2014 | 01:01 PM
bw77's Avatar
Here is a good rebuild video for the 94-97 Accord. Similar, but not exactly
the same as yours.
Old Jun 23, 2014 | 12:13 AM
jmanuel's Avatar
theyre pretty simple to fix with a gasket set from an autostore for around 25$. theres a video on youtube of someone doing it on a oddysey but its v6 but should is the same overall pump and process. mines a 98 ex. ill post link if still needed
Old Jun 23, 2014 | 06:37 PM
free_money's Avatar
All right thanks guys for the replies, I'm gonna get the kit from auto zone and try to tackle it tomorrow. We'll see how it goes. If it goes bad, at least I'll get a good forearm and bicep workout while driving.
Old Jun 23, 2014 | 10:15 PM
jmanuel's Avatar
good luck. just make sure to watch the videos and make sure you hve all the right stuff to get it done. so you wont have to make multiple trips to autostore and or get stuck on a step
Old Jun 26, 2014 | 04:06 PM
free_money's Avatar
Got the o-rings installed and now no more leaks!! It was actually rather easy to take apart the pump and install the o-rings. One thing though, the ps pump kit came with a seal in which you have to remove the pulley to replace the seal. Since I had the part I figured why not replace it. I removed the pulley then removed the snap ring. I couldn't get the gear to come out and figured it probably required a gear puller to remove it so I didn't bother. Otherwise everything is good, thanks for the help!
Old Jun 26, 2014 | 07:41 PM
jmanuel's Avatar
couldve used a rubber mallet and vise or blocks of wood to knock shaft and bearing out but thats good you got the job done a fixed the leak either way
smcdonaldaz
Acura TSX
Dec 10, 2019 01:21 PM
blackj30_a
Sep 4, 2016 06:01 PM
murrellington
May 8, 2014 03:30 PM
cmarlow4
Apr 15, 2013 06:04 PM
h22aBB4
May 31, 2007 06:10 PM
