Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
04 civic total electro loss
Old Jun 21, 2014 | 10:53 AM
Tallon22's Avatar
Default 04 civic total electro loss
This is very strange. I have an 04 civic that totally goes dead electrically intermittent when low on gas. It seems like it is getting worse. It will happen then sit for a time and be fine. I have 200k on the car and has did it to us a few years ago. The fuel level must be quite low to have this problem. Or it seems like the common denominator. It happened just recently to me when I accidentally stalled in a McDonalds drive thru. Luckily no one was behind me so I pushed it out of the drive thru and into a parking spot and went in to get the food. When I got back out it started right up again. I lost all my preset radio stations just like I replaced the battery. The battery is only 4 months old and checks out fine. Any thought of what might be causing the problem
Thanks for your time.
Old Jun 22, 2014 | 04:31 AM
lazlong's Avatar
Default Re: 04 civic total electro loss
Sounds like a loose battery cable. Start with inspecting the negative battery cable for looseness or a bad connection at both ends.
Old Jun 22, 2014 | 11:17 AM
dons2277's Avatar
sound ile the cable is your best bet at the neg side if its is tighton battery take it off the body side clean that groouund really well. also look for fuseable link.if ground is oo/k
civicron
Aug 5, 2016 05:56 AM
joshjohnson94eg
Apr 2, 2015 06:18 AM
1991crx16
Oct 17, 2011 03:46 AM
Cap'N Chronic
44
Sep 3, 2011 10:44 PM
mozzandherb
Dec 16, 2006 06:18 AM
