2000 honda civic ex. 176k miles. Knocking noise when I push the accelerator.
Old Jun 21, 2014 | 10:10 AM
diycivic's Avatar
Default 2000 honda civic ex. 176k miles. Knocking noise when I push the accelerator.
This started happening today. I have and automatic 2000 honda civic ex with 176k miles on it. When I give it gas, I hear a knocking noise in the engine. I lifted the hood to confirm and the noise is coming from the engine. Under the valve cover. Could it be a lifter? My engine has a slow oil leak from the head. I recently changed the oil and filter this past week. I was having idle issues so I removed the throttle body for a clean hoping it may help, this was a few days ago.. It seemed to help as well as help throttle response. Any idea?
Old Jun 21, 2014 | 12:09 PM
tony_2018's Avatar
Fish Twig
Default Re: 2000 honda civic ex. 176k miles. Knocking noise when I push the accelerator.
Get your valves adjusted.
Old Jun 21, 2014 | 08:22 PM
94 accord typeR's Avatar
valves normally make a ticking sound
Old Jun 21, 2014 | 09:06 PM
NotARaCist's Avatar
I never narc'd on nobody!
"From the engine" is very vague. From the head? From the block? Also, is it a tapping noise, or a knocking noise? Does it vary with RPM, or is it consistant?
Side note: Our engines don't have lifters. Cam touches rocker arm, rocker arm touches valve.
Old Jun 22, 2014 | 09:17 AM
diycivic's Avatar
It more of a tapping sound. It does vary with rpm. Speeds up the moreni mash the gas.
Old Jun 22, 2014 | 06:53 PM
diycivic's Avatar
Update. Its the rod bearings. 176k miles on the engine. Its done for.
Old Jun 22, 2014 | 07:17 PM
NotARaCist's Avatar
How did you verify that? Metallic fragments in your oil?
Morrkat1
10
Sep 10, 2018 01:28 PM
Stevo F
Jul 14, 2014 07:25 PM
artgeek09
Honda Civic (2006 - 2015)
Apr 18, 2013 01:12 PM
ccrelan
Oct 21, 2012 12:15 PM
sepetinswenze
Mar 5, 2007 04:05 AM
