93 Civic Starting issue
Old Jun 20, 2014 | 01:26 PM
ktholgate's Avatar
Default 93 Civic Starting issue
I purchased a slightly rusted standard '93 civic for $1000 in early January this year. Drove fine the first day but I expected there to be hidden problems. Distributor blew apart after 2 days. Towed it to a shop to get it fixed and have everything else checked out.
Distributor fixed, timing adjusted, rear brakes and I was good to go. Drove it to California from Utah 3 weeks later. Drive Pulley came loose while I was down there due to damaged woodruff key. Cheap fix without replacing the pulley. About a month ago it started having difficulty starting and I haven't figured it out yet.
It acts like a low battery, but the battery tests fine. If its been parked for a few hours the lights get dimmer, but it has trouble starting even if its been off only a few minutes. Turn the key and you get the low battery clicks and attempts to turn over with no success, but 1 out of every 5 tries or so it will turn over after about 10-30 seconds of attempts. The other times I hook up a jumper box and it starts up right away, but lately its been struggling there too. I don't hear any problems with the starter itself.
Any suggestions?
Old Jun 20, 2014 | 02:13 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: 93 Civic Starting issue
Just to clarify, you say battery tests fine. What kind of test(s)?
Nocturnal
10
Aug 18, 2009 12:39 AM
EgG94
Jan 2, 2009 11:13 AM
93civichatchinky
Apr 10, 2007 03:11 PM
hprelude93
Nov 24, 2005 09:25 AM
