Momo steering wheel in 95 civic DX problems
Just put a momo steering wheel in my 1995 civic DX hatchback and I am now having "issues" with the wiring for the horn. I have followed this thread to the "T" and now I am blowing the 20 amp fuse when I press the horn button. This is the thread, I have used. https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/write-up-how-wire-up-horn-non-srs-eg-civic-1926111/ I have looked for any shorts in my wiring and I have found none. The only thing that is contacting metal is the shoe horn on the back of the hub. Any help is appreciated. Thank you all.
Well something is shorting out. You just have to figure out what. Take all of it back apart and check your work step by step.
Fixed this! Ended up pulling the whole srs harness and followed the wire from the clock spring to the fuse block. For those of you who wanna do this correctly and not blow 20 fuses in the process, take the wire that is attached to your shoe horn and hook it into the srs plug that has six wires coming from it. The horn terminal is on the bottom of the plug and all the way to the left. The plug is also located on top of the fuse box. I also want to point out that I changed absolutely nothing since the above post, except the location of the power wire. Will post a picture soon, so nobody else has to struggle through this.
weavertime1
Jan 11, 2009 12:03 PM
Jaycock
Nov 11, 2004 01:21 PM
