where did this metal come from?
this is my lsvtec from last year. eventually, it lost 40 psi in cyl #1 due to a scratch in the cylinder wall. it blew most of the oil out of the motor through the catchcan, so i probably drove around with half the oil in the motor for about 5-10 miles just putting around 2000 rpm.
i found this upon teardown.
just a few pieces. is this where it came from, the backing material to the bearings?
it wasnt knocking, the crank/friction side of the bearings didnt have any excessive wear, and all bearings were still properly aligned in the rod ends with the tangs. none of the rod big ends were scored/burnt/rainbowed
just want to get some clarity on this before i reassemble it once its back from the machine shop, which should be sometime next week
i think i found it, look around the oiling hole
ok now the bigger question, what causes that? overheating? bad oil? just trying to not have a repeat performance here
How did the oil pan look? Was there a lot in there? It's not too much to be worried about. Definitely looks like bearing material. Could have been from previous build and not all the oil passages were 100% cleaned out.
no other metal in the oil, didnt look like metallic paint either.
build only had about 13,000 miles on it. it lost some compression due to a scratch in the cyl wall #1 cyl, and blew out most of the oil out of the catchcan. i caught it quickly thankfully
Hmm ok. More common than I thought. I just didnt want to have an issue with tolerance or anything and make the same mistake twice. The pieces were far to big to make it through the pickup screen and oil filter
no i didnt. i dont think i usually do. they do get a healthy coat of assembly lube on the crank surface upon assembly. ive never had a problem with it in the past
nothing excessive, but i dont remember exactly as it was last fall.
the rods are oem with arp replacement studs. they were installed, did 3 on/off cycles, then retorqued to the spec i think it was 26 ftlbs with the moly lube and brought to the machine shop to be honed out.
is the breaking apart of the bearing face around the oil holes normally caused by contamination on the oil like fuel or coolant, or is it pretty normal. i cant see it being a tolerance thing.
since the motor ran low on oil im not sure how well i can accurately look at the wear on the bearings as being indicative of proper/improper tolerance. they all plasticgaged between .0017-.0019
yeah it certainly ran on low oil.
i guess im lucky i caught it when i did before it spun a bearing or damaged the crank/rods
pinecone
15
Jun 30, 2006 11:50 AM
ulemu
12
Jan 3, 2006 12:37 PM
