rpms won't go under 3k
Old Jun 20, 2014 | 07:27 AM
bmoreb18c1's Avatar
I have a 01 gsr with a type r throttle cable and bracket and a skunk 2 IM. So recently my throttle has been acting up. When I push in the clutch pedal my rpms won't drop past 3k until I either put my foot under the gas pedal and pull it out ( even though it doesn't feel like it moves any) or if I just blip the pedal, then it drops like normal. I checked the cable to see if it was kinked somewhere or came off a mounting point but it's still attached securely at the IM, firewall and pedal. I then loosened the locking nuts a tad to give more slack at the throttle body and it seemed to help for a day or two and it's doing it again. I'm not sure if anyone has any other ideas to check or has heard of this happening but the cable is only 6 months old. Thanks for any help.
Old Jun 21, 2014 | 02:13 PM
fcm's Avatar
fcm
Old Fart
Default Re: rpms won't go under 3k
Most likely the TB, butterfly, [throttle plate] is sticking, or possibly the "pully".
Easy enough to check, disconnect cable at TB, start engine increase RPM with pully and release slowly, if RPM does not drop to normal, the problem is in the TB, if it does, it is the cable, a kink on the inner cable or just dryed out. 94
Old Jun 24, 2014 | 01:21 PM
bmoreb18c1's Avatar
Thanks man. I appreciate the input. I will try that tonight after I eat dinner
Psycho719
Apr 17, 2012 09:22 AM
Weapon_R
Aug 5, 2007 10:54 PM
mkazm83
Jul 5, 2007 08:47 PM
FOMULA91
Oct 7, 2006 12:39 PM
blunty
Apr 22, 2002 07:51 AM
