zc/d15b vtec swap in 89hf no starting
So i have all the swap in the car. I have spark and pulled the plugs and they smell like fuel. Timing looks to be set right. Tdc and cam gear at 7 oclock mark. Obd1 injectors with the resister box deleted. 4 wire O2 sensor wired in amd vtec with a ry wire harness. The car keeps cranking but doesnt turn over. Distributor set in the middle until i can start the car. All 3 grounds connected along with testing 3 z6 ecus. Im going to try and put the obd0 injectors with resistor box back in and see if that works. Any suggestions as to why its not starting? thanks in advance.
So I figured out the problem. Turns out I do have fuel. I have a code 10. I swapped the iac plug and the iat sensor plug and it starts right up. Only problem is I still have an intermittent code 10 and 12 on my p28 ecu. I'll trouble shoot the code 10 but why am I throwing a code 12? I don't have an egr lol. Anyone have the pinout on ecu side for obd1? I'll check continuity in the wires. When I drive the car after I reset the ecu, I don't have a code for a while then I get a code 10 again. Thanks for your help guys
Ok so it's pin 15 on connector D for iat sensor wire FYI.
If you had the IAC and IAT plugs swaped your code 10 may be from a melted IAT sensor. Remove and inspect it. IAT uses 5 volts, IAC uses 12 volts.
ed62ef9
22
Oct 31, 2012 02:55 PM
zchatch24
13
Feb 26, 2012 08:47 AM
