99 Civic EX build.
Old Jun 18, 2014 | 02:33 PM
ramos712's Avatar
Default 99 Civic EX build.
Well just got approved for this 99 civic EX. Unless the seller flakes I'm 99% sure that I'll be getting it. Since I'm new to the Honda world I'd like some advice on where I should go on this build.
I'm wanting a reliable, CLEAN, with a little pep kind of build. I want to lower it and put wheels on it first and foremost..
Here are the mods it currently has
99 Civic EX
  • B16a2 swap
  • New headgasket
  • New honda water pump
  • New gates racing timing belt
  • B16 trans with less than 1k on rebuild
  • Short ram intake
  • Itr factory catback
  • Itr factory shift linkage with short throw
  • factory 50/50 taillights
  • Si rear seat
  • Si springs and struts
  • Si gauge cluster
  • Si leather wrapped steering wheel
  • Si wheels with brand new tires
  • Si rear disc swap
  • Si suspension
  • Stage 2 clutch
  • New balljoints, inner and outer tie rod ends, steering bellows, wheel bearings.
Obviously all maintenance has been done so I'm starting with a solid platform.
What lowering springs does everybody suggest? I want it Low without sacrificing ride quality. Is that possible? lol
As far as wheels I've always had a thing for the Buddy club rims. Other suggestions are welcome though.
Then really all I need to know is what are the basic first performance mods you Honda folks usually do? I'd obviously like to turbocharge it down the road. Opinions on evo3 16g? I loved that turbo for my DSM's and it seems it would be small enough for a Honda.
Thank you and hope to hear all your opinions and suggestions
Old Jun 18, 2014 | 03:05 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: 99 Civic EX build.
If I recall build threads require pics too, will leave for now since you don't have the car yet but this may get edited and or moved just as a FYI.
Old Jun 18, 2014 | 03:26 PM
ramos712's Avatar
Apologies..
Here are the pics I currently have of it
Old Jun 18, 2014 | 04:04 PM
grumblemarc's Avatar
The Grumpiest
No. That's a clean car. If you get it don't screw it up.
Old Jun 18, 2014 | 05:28 PM
tony_2018's Avatar
Fish Twig
Clean indeed, maybe a lip kit thats not too wild and out plus compliments the silver. If anything find some koni's and be on the lookout for integra type r springs.
Old Jun 18, 2014 | 06:13 PM
ramos712's Avatar
Appreciate your opinion. Not one to screw up cars but each has their own preference.
I for sure want a lip. I'll be on the lookout for some Koni's.
Old Jun 18, 2014 | 07:13 PM
B_Swapped93's Avatar
Stance lyfe brah, you bout it ? get some 16x9's or 15x8 0 offset then run some stretched tires.
Old Jun 18, 2014 | 07:31 PM
tony_2018's Avatar
Fish Twig
LOL
Old Jun 18, 2014 | 08:21 PM
NotARaCist's Avatar
I never narc'd on nobody!
Your inane trolling has a time and a place, and this is neither of those.
Old Jun 18, 2014 | 08:30 PM
eghatch9295's Avatar
Stancetard Hate Monger
OP- stance is the rice of today. Just as altezza tail lights, body kits, and park bench wings were the rice of the early 2000's, stance is a stupid rice trend focused solely on appearance. difference between the godawful ricers of yesteryear and the retarded stance fanbois of today is that at least the OG ricers didnt make their cars unsafe with their horrible taste. as far as lowering goes, anything LOW isnt going to ride well, period.
Old Jun 18, 2014 | 09:10 PM
Fair enough, however these "what should I do to my car" threads of late are a little silly. My suggestion remains the same however if he did want to go down that route there are "safer" stretches then others ex: I won't do lower then a 195/45 on a 8'' rim with maybe -2 camber.
We prefer the term "hard parker"
Old Jun 19, 2014 | 05:50 AM
94 accord typeR's Avatar
tanabe springs have a comfort series the drop is only about .5 in but it retains factory ride quality
or tein coilovers for full adjustability. tanabe has coilovers but theyre almost double of the good teins
www.andysautosport.com
as for wheels i love the Honda Fit wheels and they will fit on civics 4x100mm
Old Jun 19, 2014 | 06:47 AM
tony_2018's Avatar
Fish Twig
The 2013 fit rims actually look nice, on a civic coupe dunno, on a del sol it looks awesome.
Old Jun 19, 2014 | 07:15 AM
ramos712's Avatar
Okay well it doesn't need to be ungodly low. Just lower than stock to remove some wheel gap. Other than lowering and rims I don't plan on much else as far as exterior besides a front lip. Thank you for your replies
Old Jun 19, 2014 | 02:40 PM
wheels, that's dealer's choice. personally, i don't like anything bigger than 16" on a civic/integra.
Old Jun 19, 2014 | 03:02 PM
NotARaCist's Avatar
Heavier wheel = lower effective torque. Bigger wheel = heavier wheel. For most performance vehicles, it's a balance between keeping the wheel small for weight, but keeping it big enough that you can get a good enough tire for it.
In the Honda world, that means 15" or 16" wheels, 6.5" to 7.5" wide depending on what tire you're using. What tire you use depends entirely on what you're going to do with the car. I think that breaks it down fairly easily, but do I need to make a flow chart?
Old Jun 19, 2014 | 06:41 PM
ekhatch1227's Avatar
If cost is not an issue im running full adjustable dampening buddy club coils and 15x7 +35 wheels with 195/55r15 tires.
It rides amazing. Tires arent rubber bands and you can still lower it too look nice. The wheels are flush with my fenders not "stanced" or cambered to death.
Old Jun 19, 2014 | 06:46 PM
Old Jun 19, 2014 | 07:03 PM
NotARaCist's Avatar
Yay for a link to a deleted image?
+35 isn't a horrible offset. Stock is something like +42, so as long as you keep it in the 35-45 range, you can get away with a lot of things. My Black Racing Pro N1's are 15x7, +42, and I (and most people that notice them) absolutely love them.
Old Jun 19, 2014 | 07:09 PM
ramos712's Avatar
Thanks for the replies! Just got back from seeing the car and signing some paper work so its official. Won't be able to get it for a couple days but the car is everything I expected and then some. Front bumper and hood are fading some but I can deal with that for now. The fenders need to be replaced also since their are a few dents on them. Like I said I want to make this thing super clean. Anybody have any suggestions on where to get replacement fenders? Or should I just hope CL will have something lol.
Old Jun 19, 2014 | 07:59 PM
car-part.com you can search by zip code and pick the color/condition you want
Old Jun 28, 2014 | 02:59 PM
ramos712's Avatar
So after a week of waiting on the bank to send my check and then realizing they sent the check to my old address, I FINALLY got my car. So decided to take her to the car wash and clean her up.
The work begins! First thing first I'm going to repaint this front end. As you can tell its a bit faded.
Old Jun 29, 2014 | 01:55 PM
chiprez's Avatar
This.
I'd be happy with getting the paint cleaned up and an oem lip.
The koni/itr springs sounds like a damn good idea for a daily and sporty ride.
I like fat tires so I have 205/50/15 re-11's and love them.
Good luck with the car.
Kiki001
Apr 28, 2014 10:32 AM
auto_5
Nov 25, 2010 06:32 AM
G-Sum1
Feb 25, 2009 10:24 PM
creepy116
Nov 4, 2006 03:27 AM
Project SSAP1
Aug 21, 2006 02:36 PM
