1997 ACURA INTEGRA TRANNY
Thank you all for reading my post about my 1997 Acura Integra LS AUTO. The car completely stock and has 214,000 MILES . I had recently bought this car 2 weeks ago and have been noticing some issues with the tranny. One problem is when I put it down in drive, it will kinda kick its self there, sending the whole car in a back and forth motion almost like it is forcing itself into the gear. Second is from first gear to second there is a massive jump, even in slow and steady acceleration. Let me know what you guys think!
HEEEELLLLP ME!!!!
It's probably shifting rough due to lack of maintenance and fluid flushes. I would search using the forum or google for "Acura Integra hard shifting" and see what people have or haven't done to fix or band-aid the problem.
I had similar problems in an old chevy truck all I did was add some tranny fluid and it was back to normal! Good luck, also look for tranny leaks if there is any probably would take it to a tranny shop or swap in a 5 speed!
sounds like you bought a lemon. You didnt notice this when you purchased the vehicle? Hopefully a simple transmission flush and fill will fix this. good luck with that.
But yeah, I'm going to go with the Drain and Fill. and add some stop slip for cushion.
Then i'll put an update.
PapaPark
Acura TL, RL & ZDX
17
Mar 5, 2006 08:02 PM
