94-D4 light flashing
Old Jun 17, 2014 | 04:48 PM
Steve kische's Avatar
Default 94-D4 light flashing
The D4 shift position on instrument panel is flashing no matter what gear it's in. Chilton s ays nothingand owners manual says You might have trans. problem,take it to certified Honda repair shop. I had 3 bad transmissions and no flashing,finally get good one and there it is. I just want it OFF.
Old Jun 18, 2014 | 06:31 AM
94 accord typeR's Avatar
Default Re: 94-D4 light flashing
first reset trans ecu by pulling ECU fuse from under the hood for 20 sec
if issue returns jump the code reader under the passenger side glove box and record codes
google codes or ask on here and troubleshoot from there
im assuming u have clean fluid since this is a new trans
Old Jun 18, 2014 | 11:26 AM
MAD_MIKE's Avatar
MM Gruppe B
WRONG
Steve kische if your D4 light is flashing there is a code stored in the TCU. DO NOT CLEAR THE LIGHT UNTIL YOU HAVE THE CODE. Look under the center of the glove box door, pull down the two wire blue connector. Jumper it. Turn the ignition to II(ON), record the code from the D4 light and post it here.
Old Jun 18, 2014 | 08:39 PM
Had already tried clearing code pulled fuse and power ,no difference. Just did jumper, got 2 quick flashes repeatedly .
Old Jun 18, 2014 | 11:20 PM
MAD_MIKE's Avatar
MM Gruppe B
If your D4 light is flashing twice(blink-blink*pause*) and repeats, that is for the lockup solenoids. Check that the grey connectors are properly seated, verify they are clean, tight and free form corrosion. If you have had multiple transmissions installed the connectors may have not been properly seated, or the wires may have been pulled out. Pull the connectors apart and look for damage.
Old Jun 20, 2014 | 10:50 PM
Thanks for that info One more question will I need to have that code cleared after the repair. Would like to buy you a case of whatever your drinking in that handsome profile pic.
Old Jun 20, 2014 | 10:57 PM
MAD_MIKE's Avatar
MM Gruppe B
As long as you have the factory radio code, just pull the memory fuse or the negative battery cable to clear the code.
Can't recall what I was drinking, was staring at four lights for a while, and was not allowed to sleep. Some ******** with a tongue glued to his forehead kept telling me there were five. Torture is a bitch.
But I'll take a few bottles of Corona Familiar if you insist.
Old Jun 21, 2014 | 06:35 AM
Coronas you say,very good, I will make it so captain.
Old Jun 21, 2014 | 12:08 PM
MAD_MIKE's Avatar
MM Gruppe B
Familiar...
Old Jul 6, 2017 | 11:46 AM
Zack Shelton's Avatar
Do you a pic of the two blue wires or and how to jump it please
Steve kische if your D4 light is flashing there is a code stored in the TCU. DO NOT CLEAR THE LIGHT UNTIL YOU HAVE THE CODE. Look under the center of the glove box door, pull down the two wire blue connector. Jumper it. Turn the ignition to II(ON), record the code from the D4 light and post it here.[/QUOTE]
96 civic hatch
15
May 15, 2011 03:36 AM
burnitup
Apr 6, 2006 11:44 PM
Amadeus_UK
Apr 4, 2004 03:59 PM
HXMan
Dec 28, 2002 02:50 PM
ArchAngel Sabastian
Oct 23, 2001 07:39 PM
