car won't start, help please...
Old Jun 17, 2014 | 09:40 AM
DubyaAye's Avatar
Default car won't start, help please...
i have a 99 honda accord LX 4cyl. and it won't start unless i give it a jump. i bought the battery last year and the starter was changed last month. i tested the the battery with key off engine off and its at 12.6 v and after a jump with key on engine on the battery is at 14.7v. i thought it was my alternator but according to some of my researching online, if the battery is around 14ish volts with koeo, the alternator is still good, but i can be wrong. my mechanic skills are really minimum so can someone please help..thanks
Old Jun 17, 2014 | 11:35 AM
fcm's Avatar
fcm
Old Fart
Default Re: car won't start, help please...
Your saying it will not crank, [starter motor not working] unless you give it a boost, [jump] is that correct?
If so, redo your main grounds, batt. post and cable clamp, batt. to chassis, batt. to engine/chassis to engine, DO NOT just eyeball them, disconnect/clean/reconnect.
Also, try a bypass jump without a boost...
https://honda-tech.com/forums/tech-misc-15/simple-diy-start-circuit-test-%5Bbypass-jump%5D-2961164/ 94
Old Jun 17, 2014 | 02:25 PM
DubyaAye's Avatar
i got the starter tested and its still good. one thing i forgot to mention is when i give it a jump and when it starts up it drives fine but as soon as i turn off the engine, i lose power to everything (headlights, dome lights, stereo, and etc.)
Old Jun 17, 2014 | 03:00 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Sounds like a poor ground at the battery. Disconnect the negative battery terminal, inspect and clean it and the post(in fact do that to both neg and positive,it cant hurt.)
Old Jun 17, 2014 | 05:03 PM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^ in fact, redo all your main grounds, DO NOT just eyeball them, disconnect/clean/reconnect. 94
Old Jun 17, 2014 | 05:55 PM
DubyaAye's Avatar
you're right on..the battery wires were full of gunks and after clean it it start right back up..thanks everybody for all the help
poprocksncoke
Jan 28, 2017 04:56 AM
DubyaAye
Jun 18, 2014 07:50 AM
chikin pickle
Jan 13, 2010 05:50 AM
rafiq7
Dec 14, 2004 07:46 AM
andy37
Nov 26, 2004 07:17 AM
