single vtec-e hx swap into ek few questions
Old Jun 16, 2014 | 08:04 PM
ArtyTheKid's Avatar
Default single vtec-e hx swap into ek few questions
whats up ht I have a few questions maybe someone can explain to me I'm not too sure about.
I have a ek coupe had the d16y8 in it I spun a bearing and bought a d16y5 (hx)
1. what ecu should I use? my stock p2p from my y8 or should I get a p2n hx ecu?
2. what do I do about the 2nd o2 sensor on the exhaust mani?
some help here would be great i plan on swapping this in this weekend
Old Jun 16, 2014 | 08:06 PM
Former User's Avatar
Default Re: single vtec-e hx swap into ek few questions
You probably will want to swap the y8 head/IM/TB onto the Y5 block and call it a day.
Old Jun 16, 2014 | 08:19 PM
eghatch9295's Avatar
Stancetard Hate Monger
for simplicity's sake, yes. to answer your o2 question, the primary goes pre cat, the secondary goes post cat.
Old Jun 16, 2014 | 09:08 PM
nub's Avatar
nub
This would be the easy button if the head is reusable and any metal particals a flushed out.
If you go full Y5 and P2N you'll need to add wiring for the EGR valve and the wide band primary O2 sensor.
Old Jun 18, 2014 | 04:27 PM
ArtyTheKid's Avatar
I'm gona use my y8 intake mani. so I don't need to mess with the egr at all. guess I'll be running the p2n as ppl suggested I do. but what about the secondary o2 sensor will I have to wire it straight to the ecu?
Old Jun 18, 2014 | 05:30 PM
tony_2018's Avatar
Fish Twig
The car should already have the secondary o2 sensor if it was a y8. Just swap blocks and intake manifold. I'm not sure how your mpg will change since you're losing the egr.
Old Jun 18, 2014 | 05:33 PM
HondaPartsHero's Avatar
Technical Hero
Is your car auto or manual? You'll have to use the egr if you use the P2N ecu and also wire up the 5 wire 02 if your car is manual.
Old Jun 18, 2014 | 05:41 PM
tony_2018's Avatar
Fish Twig
Word, forgot about those *******.
Old Jun 18, 2014 | 08:31 PM
yeah, just slapping a y8 manifold on it and calling it a day isnt a fix. unless you call a fix a poorly running car with a constant cel.
Old Jun 21, 2014 | 04:39 PM
ArtyTheKid's Avatar
okay we'll I have a few days before the swap can I just run my stock p2p ecu ?
Old Jun 21, 2014 | 04:43 PM
tony_2018's Avatar
Fish Twig
I don't know if the valve train is the same as a y8 head. Thats my one concern. You'll have to open the valve cover and see for yourself on that one. If it looks any different than you'll have to swap them, correctly in the same position they were in before you removed them.
Old Jun 21, 2014 | 10:52 PM
it isnt. uses roller rockers, etc. you can use your y8 head on that block with your stock ecu. the y5/y8 head combo is 9.4/1 comp, y8 is 9.6/1 iirc. Not enough that you can't use your ecu.
Old Jun 22, 2014 | 09:23 AM
ArtyTheKid's Avatar
I do not have the y8 head or I would have just slapped it on there. that's why I'm here lol okay so I got my p2n ecu and I have the hx wire harness I just need to know how and where to wire the egr and o2 sensor
Old Jun 22, 2014 | 10:24 AM
Technical Hero
What year is your civic?
Old Jun 22, 2014 | 01:13 PM
ArtyTheKid's Avatar
97 civic ex obd2a
Old Jun 22, 2014 | 01:46 PM
Technical Hero
If you have the hx engine harness and hx intake manifold once you get a 5 wire 02 it should be plug and play with no wiring needed unless I'm missing something. This is all assuming your car is a manual.
Old Jun 22, 2014 | 05:11 PM
ArtyTheKid's Avatar
okay yeah i got the 5-wire o2 sensor and it is plug and play! but now what do i do about the egr valve?
Old Jun 23, 2014 | 02:16 AM
Technical Hero
Do you have the hx manifold? if not you'll need it and it'll be plug and play. also use the hx injectors as well.
Old Jun 23, 2014 | 08:39 AM
tony_2018's Avatar
Fish Twig
You'll need everything from an hx , manifold, egr, wideband o2, ecu. If you can get your hands on the cat get it. It's specifically for this engine. I'm not sure if the hx had it but older models like the vx and the 3 stage vtec had an egr control solenoid.
Old Jun 23, 2014 | 03:59 PM
these are oddball motors. if you have to hunt down parts, you're seriously better off shelling out 100 junkyard dollars for a y8 head.
Old Jun 23, 2014 | 04:39 PM
tony_2018's Avatar
Fish Twig
Yeah.....I know.....But the mpg is awesome!!!!
Old Jun 23, 2014 | 05:43 PM
oh for sure, ive had hf/vx/hx. vx was my favorite
benscivic22
Apr 5, 2015 05:11 PM
mikehinkle
Feb 1, 2014 03:00 AM
kmcvey1989
Apr 28, 2013 06:32 PM
ajason24
Dec 22, 2009 05:39 PM
-16V-
Sep 16, 2004 08:22 AM
